Thread: What is this?
Results 1 to 20 of 32
  1. #1 What is this?
    Jul 2013
    San Bernardino,Ca
    Black piece has rubber plunger type thing inside.
    I took it off and noticed a crack in the rubber. I believe this is where my vacuum leak is coming from.
    Would this cause a random misfire code? Or engine lean bank 1 code?
  2. #2 Re: What is this?
    Banned
    Jan 2013
    Colorado
    I believe that is the acuator.
  3. #3 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    Better name for it? Lol
  4. #4 Re: What is this?
    Boost Bypass Valve.
    It can cause a vac leak.
    Misfire is likely something different, be it plugs, wires, coils, ICM.
  5. #5 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    Ok well I found a crack in it and I'm getting a P0171 code twice and P0300 code. I just bought the car 3 weeks ago and my 30 day warranty is up soon. He said my warranty will not cover a misfire code unless it has to do with the lubrication parts of the engine.
    I know it has champion iridium plugs (pulled one off today) and it looked ok. A little black though.
    So could the booster thing cause the P0171 code?
  6. #6 Re: What is this?
    P0171 is a vacuum leak, if that BBV has a tear/crack in it, it could cause the code.
    A P0300 only being covered under a lubrication parts of a warranty???
    What kinda crap is that, a misfire has nothing to do with what gets oiled in a motor and what doesnt. The misfire is almost always ignition related like I said, so plugs, wires, coil packs etc etc.
    I would remove to champion plugs and put AC delco plugs in it though, champion's are a more of a chrysler product thing.
  7. #7 Re: What is this?
    any vac leak could cause that code.
  8. #8 Re: What is this?
    Feb 2013
    37.295091, -121.930053
    Carb cleaner time
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    Is there a easy way to test the coil packs or ICM?
  10. #10 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    I'll go take a pic of one of the plugs and maybe u can tell me if they look bad?
  11. #11 Re: What is this?
    Feb 2013
    Yeah swap them
  12. #12 Re: What is this?
    Jul 2013
    San Bernardino,Ca
  13. #13 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    As for the bypass valve, think I'll go to pick a part and pocket that lol
  14. #14 Re: What is this?
    id just do a tune up. what kind of miles you got? those plugs aint factory.
  15. #15 Re: What is this?
    Feb 2013
    They look normal for beening used
  16. #16 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    2004 GTP COMP G, 85,000 miles
    I've put on 3,000 since i bought it early this month.
  17. #17 Re: What is this?
    Jul 2013
    San Bernardino,Ca
    having champion spark plugs would cause a random-misfire code?
  18. #18 Re: What is this?
    Feb 2013
    no Bad wires bad coil packs that would cause a misfire
  19. #19 Re: What is this?
    being you just bought it. what i do is, do a tune up, oil change and tranny service when i get it, as i can afford it of course. lol but this way you now have your own records for when stuff was done.
    i never take someones word when buying a car, do all the regular maint stuff as soon as a i can.
  20. #20 Re: What is this?
    Feb 2013
    Thats the best advise so far lol
