Thread: My car is making bad noises!!!!
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 My car is making bad noises!!!!
    SE Level Member boostedgtp13's Avatar
    Nh
    Ok i just installed my mail order overkill pcm yesterday drove it for a few while not beating on it, then i did a few WOT runs and it was fine, ran great, I take it for a ride this afternoon and it runs fine soo i put it in performance mode and i do a few WOT runs and everythings fine, then going up a street normally and this is what i hear. There is no SES light on and it seems to shift fine i guess. If it would help more i will take another vid of it driving. I think it may be the supercharger, i did change the s/c oil last night, i put in 2 bottles in.
  2. #2 Re: My car is making bad noises!!!!
    Apr 2009
    stockton ca
    thats ugly maybe flywheel issue or something along those lines could be a worse issue though
  3. #3 Re: My car is making bad noises!!!!
    super sounds like a cracked/broken flex plate. jack the car up, take off the covers, and inspect. you'll know if its your problem in 5 seconds.
  4. #4 Re: My car is making bad noises!!!!
    Nh
    where are the covers located ? could it be the s/c ? would taking the belt off rule that out ? i did empty two bottles of gm s/c fluid in, doesnt it only take 1 1/2 bottles ? i have no way of knowing my oil pressure
    well i took of my s/c belt and there is no play in the pulley soo it cant be the coupler.
  5. #5 Re: My car is making bad noises!!!!
    looks fast.... its slow:) beckys2000gt's Avatar
    Nov 2009
    stoystown, pa
    oh man, that dont sound good AT ALL!
  6. #6 Re: My car is making bad noises!!!!
    it not knocking with a deep, bottom end knock so i doubt thats your problem. what is your oil pressure?
    its sounds like a broken flex plate.
  7. #7 Re: My car is making bad noises!!!!
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Given the sound when you rev - x3 on the flexplate.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  8. #8 Re: My car is making bad noises!!!!
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    x4 thats exactly what it sounded like when my flexplate broke on my gf's blazer
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  9. #9 Re: My car is making bad noises!!!!
    Apr 2009
    stockton ca
    its the flex plate the cover is where the engine meets the trans under the car next to the starter
  10. #10 Re: My car is making bad noises!!!!
    Nh
    i dont know what cover, can you get me a pic please! If it's the flexplate its not expensive to replace its just gonna be a pita to replace. It's a gm goodwrench replacement tranny it cant be too old.
  11. #11 Re: My car is making bad noises!!!!
    Apr 2009
    stockton ca
    flex plates on the engine so its probably just as old as the engine if you jack the front end up and look at the starter you will see a plastic cover next to it you actually have to be under the car looking up at it
    i think there 3 or 4 bolts in it
  12. #12 Re: My car is making bad noises!!!!
    Nh
    Ok gotchya, well it looks like alot of people are saying flexplate soo i might get one from morad, well i wonder if it would hurt anymore to drive it down to the shop to have it installed, it's like 3 miles, i had to drive it 7 miles back home after i discovered the noise. Will the flexplate be all i need ?
  13. #13 Re: My car is making bad noises!!!!
  14. #14 Re: My car is making bad noises!!!!
    Nh
    am i looking for broken teeth or what ?
  15. #15 Re: My car is making bad noises!!!!
    the entire plate will be cracked, not missing teeth. it will be cracked from one or more of the bolt holes out.
  16. #16 Re: My car is making bad noises!!!!
    Nh
    ok i will look for cracks when i get to it tomorrow. I'm guessing i have to put it in neutral to turn it with my hand
  17. #17 Re: My car is making bad noises!!!!
    use a flathead screwdriver to move it along, but i bet you wont have to move it far to see its cracked. just grab the edge of it and see if you can move it side to side.
  18. #18 Re: My car is making bad noises!!!!
    Nh
    Well if it's the flexplate the problem, i found them at zzp used for $40, but dont i have to use new flexplate bolts? well should i use them is the question. and if i do i dont see them at zzp.
  19. #19 Re: My car is making bad noises!!!!
    the flex plate bolts are TTY. you SHOULD replace them with new ones (stealership trip), but you probably could get away with using the old ones and some lock tight.
  20. #20 Re: My car is making bad noises!!!!
    Nh
    oh boy torque to yeild bolts, i'm sure they are pretty stretched out soo i should just go buy new ones.
  1. 2000 3.1l Engine Noises
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-06-2010, 11:31 PM
  2. Ticking/Clattering Noises
    By FlaminWhite97GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-07-2010, 12:11 AM
  3. Various noises my car shouldn't be making
    By matt5112 in forum General Tech Discussion
    Last Post: 11-19-2009, 07:24 AM
  4. Random Sub noises
    By stoner17971 in forum Audio, Security & Visual Electronics
    Last Post: 07-07-2009, 04:56 AM
  5. K&N Air Intake noises
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 10-19-2008, 09:07 PM
