Idk i'm just looking for ideas what i can do to the motor when i get it while its out. I found one motor at a local junkyard soo far, it has 135k for $610 idk thats too high of mileage or what.
The only other thing I can think of is possibly a rocker or lifter is lose or broken.
Just another idea. I would take off the valve covers and inspect them. Might get lucky there![]()
Oh and moving to correct section![]()
Mines is making a similar noise. I just got done with an l67 engine swap from a 2004 impala ss engine + trans.
YouTube - L67 swap rough engine knock
What could be the problem?
i've seen that on a few engines other than the 3.8. those were from double gasketing. where the old seal gets stuck on the oil filter housing. a chance that happening here? just curious.
I wouldnt even know. How would the seal being stuck cause it to make that noise?
the double gasket is weak. oil pressure overcomes the rubber, as you saw it sticking out in the picture, and causes a very fast oil leak. sounds like he spun a bearing.
a bad bearing or a piston is hitting againt a valve or somethin, thats souns bad, need that fixed asap
