Thread: Cam time
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
  1. #41 Re: Cam time
    GT Level Member GeosGP's Avatar
    Fenton, MI
    your LOOSENING the cradle bolts to drop it down just enough to slide the cam in. you already have the balancer off, so taking off the front cover is just a few more bolts. if you drop the cradle too far then you have to worry about putting your steering rack back in which is a pain in the butt to say the least.
    Okay, that's too easy to NOT do during a top swap.
    Can you pull out the balance shaft while it's open too? Or is that not a good idea.
    I should probably disconnect it from spinning instead, since I'm thinking that if you pull it you'll see a drop in oil pressure because the oil will fly out from where the shaft met the bearings. Unless you seal the holes.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  2. #42 Re: Cam time
    you cant pull it out unless you plug the oiling holes for the bearings on it. i just left mine in there and disabled it so that it wouldnt move, which is a required step when installing a double roller. i am unsure if youll be able to disable it with the stock timing set.
  3. #43 Re: Cam time
    Fenton, MI
    So, how hard is it to swap in a double roller?
    Hear that? It's the sound of money flying.
  4. #44 Re: Cam time
    double roller swap is as easy as putting in a new timing chain. it doesnt require a tensioner and gets new cam and crank/oil pump gears to put on with it. the problem is that the crank gear doesnt have the right chamfer on it from the factory so they need to be modified in order to run correctly otherwise they are run out of alignment with the cam gear and may rub on the oil pump housing which will both cause the chain to break. when the correct chamfer is used then the chain will not break. just make sure it's right before you put it on. i had one on my car which i ran with a cam and when i had rockers and never had any problems for the 25k+ miles i ran it.
  5. #45 Re: Cam time
    Fenton, MI
    So, the oil pump is driven via the crank snout? Sounds just like my LS2.
    You wouldn't happen to have any pics of that stuff down there, would you?
  6. #46 Re: Cam time
    i sure dont. if you search around here you can find some. a thread just came up recently where farnsworth put up a few good pictures of it all.
  7. #47 Re: Cam time
    Apr 2009
    stockton ca
    How do you like your s1x? I may go that route instead...
    I love mine and it puts out good numbers considering im still running a 3.4 and dont have a dp/plog on yet
    and im on a canned intense tune my blower isnt ported and 91 is the best gas i can get
    when i do the pem/dp and pulley drop im going back on the dyno for sure to see the real gains maybe have it tuned as well
  8. #48 Re: Cam time
    yeah, the numbers in your signature are very promising for your setup. some exhaust work and a smaller pulley and youre going to have one hell of a monster on your hands.
    Fenton, MI
    Quote Originally Posted by TorqueAutoMotiv View Post
    Wait... no headers?
    Do you have a dyno sheet to post up? Curious on what it looks like...
  10. #50 Re: Cam time
    Outer Space
    Im a s1x lover as well.
    02 GTP 13.6 @ 100mph - SOLD
  11. #51 Re: Cam time
    Banned - Busted For Scamming
    Feb 2009
    Alright, im going s1x then. I assume the same springs/retainers/lifters can be used. Also good on a stock timing chain?
  12. #52 Re: Cam time
    assuming youre going 105# with the associated retainers then yes. stock lifters are good for anything. you can use a stock timing chain with this cam and pretty much any cam so long as you replace the tensioner when you're supposed to.
  13. #53 Re: Cam time
    Fenton, MI
    Any reason to go with anything over 105? Or am I just thinking overkill? I know you want enough spring pressure to stop valve float...
  14. #54 Re: Cam time
    depends on the cam. with big cams id go for 130# for sure. actually, because im who i am i would run 130# springs anyway and rev it to high hell.
  15. #55 Re: Cam time
    Apr 2009
    stockton ca
    Quote Originally Posted by GeosGP View Post
    Wait... no headers?
    i was scanning them and it wasnt working now they are mixed in with a bunch of papers ill see if i can find them
  16. #56 Re: Cam time
    Fenton, MI
    That seems like great power for not having headers. If I can get away without them, I will.
  17. #57 Re: Cam time
    Apr 2009
    stockton ca
    im running stocker chain new ofcourse the springs were tested out at 110#s but they came with the heads i got from a member on here
    new stock lifters used my old pushrods just cleaned them up and tested for straightness
  18. #58 Re: Cam time
    Apr 2009
    stockton ca
    currently on the 3.4 pulley i have zero kr aswell ill dp and put the pem's i have in my garage on before the 3.2
  19. #59 Re: Cam time
    Fenton, MI
    I would imagine you'd see pushrods that are messed up if our cars came with a manual transmission. Not saying that it doesn't happen, but I think the incidence is far lower than say with an F-body.
  20. #60 Re: Cam time
    Fenton, MI
    I have a front plog, planning on doing a DP, then playing with the pulley size and a tune. Should be interesting.
  1. Part time headlights, all the time
    By myzon26 in forum General Tech Discussion
    Last Post: 03-04-2010, 08:23 AM
  2. asking one last time before i do it...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-02-2009, 02:50 PM
  3. First Time
    By purplehaze97 in forum Introductions/Noob Questions
    Last Post: 02-16-2009, 04:49 AM
  4. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  5. Might be time to go
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 02-09-2009, 06:03 PM
