There is a wedge-tab on the BACK side of the connector as viewed through the access hole. Do NOT use a sharp object. You need to depress the tab and pull the connector out. Do not attempt to remove the blue part, as you will break the plug. I have a photo-writeup around here somewhere that shows how to take it apart...
