Thread: help 2007 grandprix 3.8L V6 SFI
Results 1 to 4 of 4
  1. #1 help 2007 grandprix 3.8L V6 SFI
    texas
    I've had an intemittant problem with my car stalling while driving and not restarting. took it to the dealer and they first replaced the fuel pump module and a inaccurate fuel level sensor in june 16 2008. I had the same issue again with the car stalling on July 1, 2008 took it in and they said no codes stored in any modules, loss of spark when cranks wont start. No signal from PMC the check crank sensor it was ok. they repalced and programmed PCM it started then stalled. no power from UBEC to starter at times on purple wire. They replaced UBEC for intermittant open at starter relay & IGN swich for high ressistance through cranking circuit. parts replaced PCM 3.670, Block 2.483, B/0 chg, switch 2.188
    picked car up on July 11 same issue on on July 15 dealer replaced the crank sensor and switch parts switch 1.800 and SEN ASM 2.383 picked car up on July 23. Happened again Nov 27,2009 they again replaced crank sensor and ignition module. Has any one else had these issues? any help would be great
  2. #2 Re: help 2007 grandprix 3.8L V6 SFI
    PA
    It should be under warranty. Let the dealer fix it.
    But really, I don't understand what all the numbers mean in your post. I got confused.
    2001 GSE
  3. #3 Re: help 2007 grandprix 3.8L V6 SFI
    GT Level Member supercharged06's Avatar
    capecod
    Check the Cam sensor? Fraied wire? could ground out, a never know....that is weird tho
    '06 GT Supercharged
  4. #4 Re: help 2007 grandprix 3.8L V6 SFI
    just shy of one year old.
    If he didnt solve it, he probably sold it shortly thereafter.
  1. 1997 and 1998 grandprix
    By zipzat in forum General Tech Discussion
    Last Post: 11-09-2009, 03:26 PM
  2. 1988 grandprix tranny to 1993 grandprix
    By avaitors in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 09-14-2009, 03:34 AM
  3. 04 grandprix wiper problem
    By sasquatch094 in forum General Tech Discussion
    Last Post: 09-08-2009, 07:04 AM
  4. 92 grandprix trouble
    By GAbriel in forum General Tech Discussion
    Last Post: 03-17-2009, 01:55 PM
  5. New to the grandprix!
    By SnMman in forum Introductions/Noob Questions
    Last Post: 06-23-2008, 01:30 AM
