Thread: cleaned tb, car wont start been 3 days
Results 1 to 4 of 4
  1. #1 cleaned tb, car wont start been 3 days
    SE Level Member e6600's Avatar
    Los Angeles
    i used crc tb cleaner and it said not to use on supercharged/turbo engines but figured it wouldnt matter so i cleaned it anyways
    we waited till it dried then started up the car and it died after a few seconds and havent been able to start it since. i checked the tb a day ago and it was pretty wet all over so i let it dry for 10 hours and still wont start
    maybe one of the sensors on the tb is bad? i only removed the maf sensor when i cleaned it, and apparently all the dirt collected where that spring thing is so i cleaned it with electrical cleaner
    its a 99 regal gs
    98 grand prix gtp: stock until i fix problems
  2. #2 Re: cleaned tb, car wont start been 3 days
    Delaware, OH
    Try unplugging the MAF and see if it'll start. Our cars have a basic Speed density tune that'll let them run without a MAF. Won't run the best but it'll still get you from point A to point B.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  3. #3 Re: cleaned tb, car wont start been 3 days
    Sounds like a big vacuum leak. Sure you put the TB gasket on the right way?
    If not...try the unplugging the MAF like mentioned...if it runs unplugged...then you got a bad MAF
  4. #4 Re: cleaned tb, car wont start been 3 days
    Los Angeles
    i unplugged the maf and car still didnt start
    but the gasket is broken at the bottom.. hopefully its that
    sounds like its not getting fuel
  1. Wont start
    By EmEaston24 in forum General Tech Discussion
    Last Post: 08-27-2009, 09:20 AM
  2. ran out of gas , now it wont start
    By jbon64 in forum General Tech Discussion
    Last Post: 12-25-2008, 02:27 PM
  3. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  4. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
