Thread: 1.9 Modified Rocker Install
Results 1 to 20 of 37
  1. #1 Re: 1.9 Modified Rocker Install
    Glad to hear you got all the bugs worked out man. Get it re-tuned for those 1.9's though as your final mod
  2. #2 Re: 1.9 Modified Rocker Install
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    This is a response from Will I got last year in contemplating the rocker and Tb install.
    On Sat, Jan 24, 2009 at 7:31 AM, <Kissmyss> wrote:
    Hi Will, will I need a retune to install a 72mm throttlebody and 1.9 modded rockers.
    willoverkill@gmail.com writes:
    The rockers shouldn't need retuning, install and enjoy. The throttle body depends on what you'd be installing; the Stage 1 ZZP for example would be fine as it does not modify the area where the MAF sensor is located, however the Stage 2 unit would need retuning as it modifies that area and throws off the MAF calibration. I would recommend the Stage 1, or if you want to do a real upgrade go right for the Northstar kit or a billet 78mm.
    The Northstar, 78mm billet and Stage 2 72mm throttle bodies all require retuning. The Stage 1 72mm does not, however it isn't enough of an upgrade that I would recommend it. Go for the Northstar unit and don't worry about the TAC, just a standard TPS adapter is required and all changes required for the Northstar will be retuned into the PCM.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  1. write up on rocker install?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2010, 08:07 PM
  2. 1.9 modified rocker installation
    By rolyat in forum General Tech Discussion
    Last Post: 01-26-2010, 12:54 AM
  3. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  4. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
