Thread: car wont turn over after failed header install
Results 1 to 20 of 37
  1. #1 car wont turn over after failed header install
    MA
    I tried to get my headers installed but i ran out of time..so i turned back and put in the original manifolds and cross over, now she wont start and im still on a deadline i basicly need this done within the hour soo any and all help will be greatly appreciated
    soo here is some of the things that i think could be the problem
    1) when taking out the front o2 sensor the prongs in the harness popped out, i dont believe any wires broke but im not sure if theyre in the correct order
    there is four prongs, if they are out of order would that prevent the car from starting up? and if you can help me figure out the correct order thatd be great too, if not i can toy around
    2) i left the crossover open where it meets the rear mani, i figured itd be no big deal but i dont know if its skewing the o2 readings thus preventing the start up
    i left it open becuase the two bolts snapped in the rear manis flange and i couldnt get them out
    im cleaning my spark plugs now hoping that it is just some oil/ grease that is not allowing the spark to transfer from the wires
    SMGPFC Member #9
  2. #2 Re: car wont turn over after failed header install
    Charles City, IA
    02 sensor would not prevent the car from starting. start simple is the battery connected? did you unplug the icm under the coil packs to move the wire?
    SMGPFC Two Nipple General
  3. #3 Re: car wont turn over after failed header install
    MA
    battery is connected, didnt fondle with any ignition besides wires and there in the right order
    SMGPFC Member #9
  4. #4 Re: car wont turn over after failed header install
    MA
    all i need it for it to make the 1/2 hour trip up to my mechanics shop while i go away on business, but as of now its not leaving the driveway
    SMGPFC Member #9
  5. #5 Re: car wont turn over after failed header install
    Banned - Busted For Scamming
    Feb 2009
  6. #6 Re: car wont turn over after failed header install
    MA
    prongs got pulled after that, straight out of what plugs into that, the colors are different
    SMGPFC Member #9
  7. #7 Re: car wont turn over after failed header install
    MA
    this is gonna cost me a sh!t load of money that i dont have right now
    SMGPFC Member #9
  8. #8 Re: car wont turn over after failed header install
    MA
    would the crossover being unbolted from the rear mani effect it enough to shut it down?
    SMGPFC Member #9
  9. #9 Re: car wont turn over after failed header install
    Charles City, IA
    do you have a test light or multimeter?
  10. #10 Re: car wont turn over after failed header install
    Charles City, IA
    make sure you are getting power to the big and little wire on the starter.
  11. #11 Re: car wont turn over after failed header install
    MA
    no i dont
    i didnt play around with the starter, so im assuming its alright, but i wouldnt know how to check otherwise
    it turns over and i can keep it going if i gas it but other wise it cuts out
    SMGPFC Member #9
  12. #12 Re: car wont turn over after failed header install
    Charles City, IA
    cutting out unless staying on the gas sounds like you have a big vac leak check the hose going to the break booster.
  13. #13 Re: car wont turn over after failed header install
    MA
    i will now thx
    SMGPFC Member #9
  14. #14 Re: car wont turn over after failed header install
    MA
    thanks for helping mini but if thats not preventing it from running then honestly its not a high priority
    SMGPFC Member #9
  15. #15 Re: car wont turn over after failed header install
    MA
    [QUOTE=01GTP;359008]cutting out unless staying on the gas sounds like you have a big vac leak check the hose going to the break booster.[/QUOTE
    im an idiot can you elabore more on where to look, honestly dont know where brake booster is and i dont see any vac lines where i thought it was, which was by the fluid resevoir
    SMGPFC Member #9
  16. #16 Re: car wont turn over after failed header install
    Charles City, IA
    [QUOTE=SilvaMan61;359019]
    It is the big line that goes on the top of your blower to the big black thing behind your master cylinder.
  17. #17 Re: car wont turn over after failed header install
    MA
    i am hearing a hissing when it fires up soo it probably is the vac leak.......
    the rpms will jump up to 1.5k and drop straight back down
    SMGPFC Member #9
  18. #18 Re: car wont turn over after failed header install
    MA
    i dont see a problem with that, no visable cracks or tears, and it is snuggly plugged in on both sides..just to confirm...its a rubber hose goes from the black "thing" in the back of engine compartment to a black circular thing in between the throttle body and vblower correct?
    SMGPFC Member #9
  19. #19 Re: car wont turn over after failed header install
    MA
    i know its probably frustrating trying to work with a moron but hang in there lol
    SMGPFC Member #9
  20. #20 Re: car wont turn over after failed header install
    Feb 2009
  1. TCS wont turn on
    By jmalin72207 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:19 AM
  2. car wont let me turn it off??
    By 02blackgpgt in forum General Tech Discussion
    Last Post: 04-25-2009, 08:14 AM
  3. please help, air wont turn off
    By red60degreeGP in forum General Tech Discussion
    Last Post: 04-23-2009, 06:26 PM
  4. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
  5. Car wont turn off !?!
    By Billyboi6 in forum Northeast
    Last Post: 11-11-2008, 12:54 PM
