Thread: Finally its done. i hope. but one little problem.
Results 1 to 20 of 23
  1. #1 Finally its done. i hope. but one little problem.
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    So i got the car done. Noise i was hearing at 2000-3000 rpm is gone. now that the xpz is out that is. i think the problem was the length rods i was running. but idk though i could be wrong as im not a professional(yet). hell it could even been the massive exhaust leaks i was having. Now fixed. The ZZP Headers i have had to be modified. Read my other thread on that. But i have one question. The only thing wrong with my car right now is a vacuum leak because my LTFT at idle shows 16.4. Now i can hear a wistling right by the snout. I previously took the ic apart. I resealed it after clean. Could it possibly be leaking from there? i didnt cake the whole surface with rtv when resealing instead i used a thin coat besides in the 2 bores on the plates for the inlet/outlet of HE i used quite a bit. Should i used a little more to where it squeezes out when the plates are tightened? Also, im using the silicone baking sheet idea as my gaskets. They are cut accordingly for everything.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: Finally its done. i hope. but one little problem.
    i would guess that the intercooler is the vacuum leak as well. i never did like the idea of introducing another couple places for leaks into the system.
  3. #3 Re: Finally its done. i hope. but one little problem.
    can i use starter fluid to trace the leak?
  4. #4 Re: Finally its done. i hope. but one little problem.
    on my aeroforce. it shows like 8.2, 9.4 but not 16.4 this morning. took it for a drive and right when i let off the throtle the trims shoot to 16.4. could an exhaust leak also cause a 16.4 LTFT?
  5. #5 Re: Finally its done. i hope. but one little problem.
    Banned - Busted For Scamming
    Feb 2009
    Is it idling high or running rough?
  6. #6 Re: Finally its done. i hope. but one little problem.
    its idling at 1000 RPMs. I cant get the powrtuner that i just got to recognize the interface for first run registration or something like that. im just reading these parameters off my aeroforces for now. Could it be just that my fuel trims are resetting themselves possibly? The car doesnt seem to run rough. A few quick taps on the throttle at idle and its like it skips if that makes sense. my o2 is bouncing up and down between 55 and 875. my map inHg/psi is round the -13's. and when the oil cap is removed it sucks my hand
  7. #7 Re: Finally its done. i hope. but one little problem.
    Feb 2009
    Sounds like you have a restricted pcv inlet because it should not suck your hand.
  8. #8 Re: Finally its done. i hope. but one little problem.
    Put a breather on the VC
  9. #9 Re: Finally its done. i hope. but one little problem.
    the ****ty thing is i sold my breather.
  10. #10 Re: Finally its done. i hope. but one little problem.
    would it be better to run an external pcv setup?
  11. #11 Re: Finally its done. i hope. but one little problem.
    that would be a much better option than running a breather.
  12. #12 Re: Finally its done. i hope. but one little problem.
    i think i found the leak. last night i was sprayin carb cleaner around and sprayed right at the inlet/outlet of the ic core. sprayed it like 7 times and idle changed everytime and the whistling at idle went away for a split second everytime i sprayed it as well
  13. #13 Re: Finally its done. i hope. but one little problem.
  14. #14 Re: Finally its done. i hope. but one little problem.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Um, no. Unmetered air is a bad thing.
    How did you plumb up the inlet on the PCV? The Gen V requires you to do it yourself, as it's routed completely differently than the Gen III.
    2001 Buick Regal LS - Almost Stock
  15. #15 Re: Finally its done. i hope. but one little problem.
    Wichita, KS
    GenV's are easy to plumb, they give you that fitting on the back side of the case, and you plumb that into the intake tube after the MAF, and before the TB.
    If your talking about modifying the stock PCV system, that's a whole nether ball game.
    ~F~
  16. #16 Re: Finally its done. i hope. but one little problem.
    QCA, IA
    I know it's not hard, I was just wondering how he had it set up since it's obviously blocked.
  17. #17 Re: Finally its done. i hope. but one little problem.
    just how farns explained is how mine is routed.
  18. #18 Re: Finally its done. i hope. but one little problem.
    intercoolers suck.
    PRJ core or go home.
  19. #19 Re: Finally its done. i hope. but one little problem.
    Quote Originally Posted by Scimmia View Post
    Maybe I just need to start using smileys for sarcasm?
    LOL
  20. #20 Re: Finally its done. i hope. but one little problem.
    Topeka, KS
    Since you mentioned that you used silicone baking sheets as a gasket where did you buy yours from ? I've been meaning to get one and use it for tb gaskets for my Meth install.
  1. Sunroof still leaks...FOUND PROBLEM FINALLY
    By 99prixgt in forum General Tech Discussion
    Last Post: 05-19-2011, 09:52 AM
  2. new to site...have a problem hope you can help!
    By bbygrl75 in forum Introductions/Noob Questions
    Last Post: 03-12-2010, 03:21 PM
  3. Newbie here...have a problem, hope u can help...
    By Timandshannon in forum Introductions/Noob Questions
    Last Post: 03-09-2010, 11:32 PM
  4. Maybe I FINALLY found the problem..?
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2010, 02:43 PM
  5. :( no hope
    By LogicGTP in forum Track Sessions and Kills
    Last Post: 02-18-2009, 04:52 PM
