Thread: 04 gtp canister fit in an 01 GT?
Results 1 to 3 of 3
  1. #1 04 gtp canister fit in an 01 GT?
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    Wondering if the venturi fuel canister would fit. I know their are issues with 97-99. With the new fp I need a gtp canister and idk I figure it should work.
    Advice?
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  2. #2 Re: 04 gtp canister fit in an 01 GT?
    I thought the '04's had the returnless fuel system and non-serviceable filter...to where everything was in the pump...I could be wrong though. If I'm right...then I'd say you couldn't use it.
  3. #3 Re: 04 gtp canister fit in an 01 GT?
    Nov 2008
    NY
    Well that's what I figured since the 04+ are return less it wouldn't work. But I'm still curious lol.
  1. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
