Thread: LIM leak
Results 1 to 20 of 20
  1. #1 LIM leak
    Jan 2009
    connecticut
    Yesterday I noticed my LIM is leaking and took it to the guy who does all my car work, which he confirmed what i thought. He gave me an estimate of $600-$800 does this seem reasonable? He also said that everything has to come off the top of the motor including the valve covers, rockers and push rods. is this true? If he is correct and the rockers do need to come out I was thinking about having him put the 1.9 rockers in. Would I need a retune if i had him do that? and would the gains be worth it?
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  2. #2 Re: LIM leak
    Jul 2008
    sumter,south carolina
    omg lmfao.... 600-800 bucks!!!!! no that doesnt sound right at all. i can only imagine what hes been charging u for other stuff.. id find another mechanic.
    02 GTP with mods 05 GP for DD
  3. #3 Re: LIM leak
    Jul 2008
    i just checked on ALLDATA PRO, most dealerships use this program to price jobs... it calls for 3.6 hrs labor and part is $66.40 so ur mechanic is tryin to charge u 200 bucks a hour pretty much.
  4. #4 Re: LIM leak
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    valve covers, rockers and pushrods def dont need to come out hes on crack
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: LIM leak
    Jul 2008
    more like fuel rail.. supercharger.. all the lil bullsh*t in between... theres a writeup in the how to section to do this.
  6. #6 Re: LIM leak
    GTP Level Member Scimmia's Avatar
    QCA, IA
    He's thinking of a 60* V6 intake gasket job. Those engines need to have the pushrods removed to take the intake gaskets out, which is why you would need to remove everything. For one of those engines, that price is not out of line at all.
    2001 Buick Regal LS - Almost Stock
  7. #7 Re: LIM leak
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    find a friend or member here to help ya. thats alot of $$$$ he's trying to get outta you.
  8. #8 Re: LIM leak
    Apr 2009
    stockton ca
    Yea its a easy enough job Takes a few hand tools and a few hours
    Helped a member on here with thiers last weekend when all was said and done id say we had 5 hours into it with cleaning parts very well and doing the valve cover gaskets
    His quote from gm was higher then that but they have included a new intake mani (was a gt)
  9. #9 Re: LIM leak
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    he s charging you on prices for a 3400 v6 i think he mixed your car up for a grand am gt thats called for 6 hrs on all data thats what my shop goes by
  10. #10 Re: LIM leak
    Jan 2009
    connecticut
    I couldn't imagine what the dealer would charge. When I first got the car, the valve cover gaskets were leaking. Dealer estimate for new gaskets was $695, I couldn't belive it, what thieves. I will talk to the guy better tomorrow. With my business I dont have alot of free time to mess around with the car, so sometimes it's just easier to pay someone to do it. I know this guy is álmost always more expensive than most mechanics in the area, but he's very particular and builds cars from the ground up, I know he will do the job right.
  11. #11 Re: LIM leak
    GT Level Member rmcardle3's Avatar
    Houston, TX
    Quote Originally Posted by GMPUNK View Post
    Maybe I am missing something but, is this a GTP? What year? Didn't they do a dealer recall for the leaking valve covers that catch on fire? If so, isn't that a free valve cove gasket and free labor? If it is not a GTP, my bad.
  12. #12 Re: LIM leak
    Houston, TX
    Really tough to find your info. Are you NA or Supercharged?
  13. #13 Re: LIM leak
    Jul 2008
    omfg do the ppl thats wondering if its a GTP read signatures at all... he has a 3.5 pulley... do N/A's have supercharger pulleys? uuhhhh no.
  14. #14 Re: LIM leak
    Apr 2009
    stockton ca
    And well its posted in the supercharged section
  15. #15 Re: LIM leak
    Jan 2009
    connecticut
    Well today I had a friend help me change the gasket, it took us awhile to do being neither one of us have ever changed one before. I changed the oil and all new antifreeze. no leaks so far and while i was in there i changed out my autolite 605's for 104's.
  16. #16 Re: LIM leak
    Dec 2008
    hueytown, alabama
    congrates....don't u feel better for not giving that dude all that damn $$$$$??
  17. #17 Re: LIM leak
    Houston, TX
    Quote Originally Posted by wickedintent79 View Post
    GMPUNK sorry I missed the 3.5 pulley thing and sorry you didn't get the message in time to cash in on the recall.
    You might be entitled to a free dealer, front and rear valve cover gasket plus labor, maybe it is posted in the supercharged section, and under DIY job…..oh….no…wait..
    It’s a RECALL!
    Maybe not, but just in case.
    APR 08, 2009 | Recall ID# 60166
    MAR 12, 2008 | Recall ID# 71015
    It’s all good.
  18. #18 Re: LIM leak
    Houston, TX
    It’s a RECALL!
    FYI
  19. #19 Re: LIM leak
    SE Level Member peejmeister's Avatar
    lucas
    Too bad the recall only allows for one replacement set? Or at least that's what my dealer tells me after the ones they put in a couple years back on both my wife's GTP and my Regal GS are leaking (and perhaps causing a new fire hazard?) again.
  20. #20 Re: LIM leak
    Houston, TX
    Quote Originally Posted by peejmeister View Post
    Gotcha, my bad.
  1. oil leak
    By littlenoz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-15-2009, 07:19 PM
  2. Vac leak?
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 07:24 AM
  3. Oil Leak
    By streetsmart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:45 PM
  4. s/c leak
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2009, 06:30 PM
  5. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
