Thread: MAF Sensor
Results 1 to 13 of 13
  1. #1 MAF Sensor
    SE Level Member whodat79's Avatar
    neenah
    Well i finally took my car out on its maiden voyage (after the winter mods)! I found out my car was not running right and code p0102 kept showing up. i unplugged my MAF sensor and it ran better than it was! i've been told its uncommon for them to fail... is there a way to test with volt/ohm meter to figure out if its good or bad or if the sensors just needs to be cleaned?
    2000 GP GTP....
  2. #2 Re: MAF Sensor
    Willoughby, Ohio
    You can try cleaning it but if it doesn't run right still then it needs replaced
  3. #3 Re: MAF Sensor
    Troy OH
    it'll run like an absolute dream if you replace it. i tried cleaning mine with the cleaner you get at autozone a couple times and it didn't do anything. if you bring the core in, it's only like $130 and it's a lifetime warranty. just curious, have you checked for knock? that could be another reason it's not running well, you never know with just getting back out.
  4. #4 Re: MAF Sensor
    Banned - Busted For Scamming
    Feb 2009
    Quote Originally Posted by whodat79 View Post
    Just fixed mine, it was the maf fuse blew for some reason and it was not the sensor. Same code. Its the low input code, as in the computer doesnt see the correct voltage/frequency its looking for. The maf itself was getting no power.
    You should have 12v with ignition in run position on pin C if not check the minifuse 21, its a 15A located in the underhood fuse panel on pass side engine bay. Make sure you also have a good ground at pin B.
    Hope this helps!!
  5. #5 Re: MAF Sensor
    neenah
    I'll check the fuse but if its not the fuse.... i was thinkin of going to a local junk yard and seeing if there a MAF that i could buy for cheap. thats why i was asking for a volt meter reading. if there isn't a to test for a good MAF at the junk yard then i guess i'll just "Bit the bullet" and buy a new one from autozone for $135. GM wants $366 WOW
    2000 GP GTP....
  6. #6 Re: MAF Sensor
    neenah
    Ok now i'm @ a loss... I'm still getting the same code. I have replace all vacuum and the MAF sensor (sensor i bought new). Any thougths? HELP PLEASE
    2000 GP GTP....
  7. #7 Re: MAF Sensor
    neenah
    BTW the new sensor did fix the idle problem and the hick up on acceleration!
    2000 GP GTP....
  8. #8 Re: MAF Sensor
    Jul 2008
    sumter,south carolina
    did u clear the code out?
    02 GTP with mods 05 GP for DD
  9. #9 Re: MAF Sensor
    Troy OH
    x2, mine registered 3 times when it went bad for some reason.
  10. #10 Re: MAF Sensor
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    got a replacement from advanced and had to get another because the reman. was bad check that to now it runs awesome
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  11. #11 Re: MAF Sensor
    neenah
    ya i clear the code several times and still comes up!
    2000 GP GTP....
  12. #12 Re: MAF Sensor
    Michigan
    I have a 99 Grand Prix GT with 186k. I get an engine flucuation (1900-2300rpm) when its under a load such as trying to increase acceleration from a steady cruising speed. The occurs at 1900-2100 rpm & a speed of about 55mph. It takes an increase of the gas pedal, to make it stop going up & down (tach needle) of aprox. 2600-2800 rpm & a speed of aprox 65 mph or getting on a level road which eliminates the load/ drag on the engine. Could this also be a MAS/MAF problem as you are discussing here?
  13. #13 Re: MAF Sensor
    Troy OH
    it could be, but you'd have a check engine light. a few of us actually were talking about this in another thread not too long ago, and the solution we came up with was that the pcm throughout the years accounts for "wear and tear" on drivetrain components and changes things like fuel trims and transmission line pressures. solution: leave the battery unhooked for a few hours, or overnight. it drains all power from the pcm and resets to factory defaults. it worked for me and a couple other people
  1. bad map sensor?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2022, 06:58 AM
  2. O2 Sensor
    By Ibwrong in forum Off Topic Discussion
    Last Post: 01-10-2010, 01:51 AM
  3. No o2 sensor ??
    By Bigbm80 in forum General Tech Discussion
    Last Post: 07-07-2009, 05:55 PM
  4. ? about my maf sensor
    By ponycarman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-04-2009, 11:39 AM
  5. o2 sensor
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 06:12 PM
