Quote Originally Posted by whodat79 View Post
Well i finally took my car out on its maiden voyage (after the winter mods)! I found out my car was not running right and code p0102 kept showing up. i unplugged my MAF sensor and it ran better than it was! i've been told its uncommon for them to fail... is there a way to test with volt/ohm meter to figure out if its good or bad or if the sensors just needs to be cleaned?
Just fixed mine, it was the maf fuse blew for some reason and it was not the sensor. Same code. Its the low input code, as in the computer doesnt see the correct voltage/frequency its looking for. The maf itself was getting no power.
You should have 12v with ignition in run position on pin C if not check the minifuse 21, its a 15A located in the underhood fuse panel on pass side engine bay. Make sure you also have a good ground at pin B.
Hope this helps!!
