Thread: Gen V torque sequence problem
Results 1 to 8 of 8
  1. #1 Gen V torque sequence problem
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    So im putting the supercharger back on and torquing it down. Torquing at 17ft lbs in the right sequence. All is good till i get to #7 bolt in sequence and the supercharger wont spin freely. Feels like it is catching on something. So i loosen in back up and finish up on 8, 9 and 10 and it spins fine. So then i just try tightening it after all other bolts are torqued and still does it.
    What do u guys think could be the problem? Warped case?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: Gen V torque sequence problem
    i never use a 'sequence'. i just started at one side and did a cross pattern until i met in the middle on opposite sides. you just need to make sure its not binding after torquing, which it is. i also never really torqued it, just hand tightened it all and called it good.
  3. #3 Re: Gen V torque sequence problem
    so it doesnt necessarily suggest that i have a warped case?
    fcuk i sure hope not, just had the damn thing fully polished. lol
  4. #4 Re: Gen V torque sequence problem
  5. #5 Re: Gen V torque sequence problem
    do u have a sequence i can look at handy to compare mine to it?
  6. #6 Re: Gen V torque sequence problem
  7. #7 Re: Gen V torque sequence problem
    Portland Oregon
    I just went around the darn thing in a circle.
  8. #8 Re: Gen V torque sequence problem
    ^^Like that...and just tightened it until my tiny Burger King arms couldn't turn it anymore...granted I didn't torque them to like 100 ft.lbs, but you get hte idea...and I never had a blower issue.
  1. Lug Nut Torque
    By hacket in forum Tires & Wheels
    Last Post: 04-10-2010, 07:04 AM
  2. big torque
    By badbrad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 11:14 PM
  3. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  4. Torque anyone?
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 06-18-2008, 10:20 AM
  5. torque..?
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-03-2008, 11:13 PM
