Thread: what pulley?
Results 1 to 9 of 9
  1. #1 what pulley?
    SE Level Member RICE KILLER's Avatar
    st. paul mn
    ok so i am about to start ordering parts for my gtp and here is what i am going to do as far as mods.
    -FWI
    -SSAC headers
    -1.9 rockers
    -ported TB and SC
    -DPH PCM
    -180* T-stat
    -104 autolites and new wires
    -modular pulley system
    so i was going to go with the 3.4 pulley but do you guys think i could go smaller? also does any one else have the same or similar set up; if so what were the results?
  2. #2 Re: what pulley?
    st. paul mn
    my bad i didnt mean to post 2
  3. #3 Re: what pulley?
    GTP Level Member
    Nov 2008
    MA
    you need to add a scanner to that mod list and ditch the pcm and get a custom tune to make the most from that setup..noone can tell you what pulley you can run..ive seen ppl with KR from a 3.4 w/ that setup and ive seen others with the 3.3 KR free, every car is dif. this is for a 97-03 setup, if you have an 04+ you wont be able to run as small of a pulley
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  4. #4 Re: what pulley?
    start with a 3.4 and see how it goes.
    Whatever you can run with stock or higher timing is what i'd go with.
  5. #5 Re: what pulley?
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    x2 on ditch the dhp pcm and go for a custom tune
    I made that mistake on my car and ending up needing a custom tune anyways. However, it's still better than stock :-)
    2004 GTP CompG - 3.6" ZZP MPS, K&N CAI, 180* Tstat, SSAC Headers, ZZP Flex, high flow cat, borla exhaust, DHP/danthurs tune, AL104s, ZZP Wires, alt re-wire, slotted/drilled rotors, 35% tint, alpine amp + sub
  6. #6 Re: what pulley?
    Wausau, WI
    go for a custom tune. forget the DHP....it has too much timing IMO out of the box and I get knock on a 3.4...I bet I could eliminate the knock if I had a custom tune.
  7. #7 Re: what pulley?
    Sheboygan, WI
    Quote Originally Posted by Liquifire View Post
    I get knock on mine with a stock pulley! 04 compg
  8. #8 Re: what pulley?
    even with headers?
  9. #9 Re: what pulley?
    Sheboygan, WI
