Thread: Bad fuel pump
Results 1 to 8 of 8
  1. #1 Bad fuel pump
    Rockford, IL
    Well isnt it my lucky day go out turn the key and nothing. I dont hear the fuel pump kicking on, checked all the fuses and there all good and it wont start like its not getting gas. Does it seem right autozone wants 260 for a new one? Well my question is where exactly is it located? Im hoping you dont have to drop the gas tank but I cant find any forums on "how to", or location or nothing.
  2. #2 Re: Bad fuel pump
    Jul 2008
    sumter,south carolina
    the pump is accesible through the trunk... where the cupholder thing folds down it back seat, its right behind there under the carpet.. it has several little bolts holding on access panel... did u check the fuel pump relay also? price on pump sounds reasonable.. i replaced one a few years ago and i paid over 300 for mine.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Bad fuel pump
    Topeka, KS
    You can get an upgraded one cheaper than 260.00
    Here's a replacement pump from WBody Store for $100.00 W Body Store
    Here's a Stock Drop In For $159.00 that needs no modification. W Body Store
    Stock pump... $79.00 http w/o canister http://www.wbodystore.com/grandprix/...uri-p-264.html
  4. #4 Re: Bad fuel pump
    Jul 2008
    ^ where were u when i replaced mine.
  5. #5 Re: Bad fuel pump
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    That is great info, thanks. I kept my stocker with the bucket and sender when I bought a new Airtex pump assy for over $300. What a fool I felt like after learning about the much cheaper alternatives. (In my own defense it was Christmas Eve when the pump went out and I had a critical need for the transportation so I basically bought one from the first place in town that had one in stock) I will be upgrading to the 255 soon and I'll sell you my airtex for $110 .
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  6. #6 Re: Bad fuel pump
    Topeka, KS
    Sorry To Disappoint....
    Research man, it saves you money
  7. #7 Re: Bad fuel pump
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Check the fuel pump resistor first.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  8. #8 Re: Bad fuel pump
    Rockford, IL
    Wow way more helpful than I thought. Thanks alot saving money always helps, and knowing I dont need to drop the tank.. Why isnt there a "write up" though? Theres gotta be people like myself new to GM an there expensive products lol
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  3. l32 vs l26 fuel pump
    By rodman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 08:15 PM
  4. Fuel Pump?
    By 03BCprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2008, 11:59 PM
