Re: DNA Headers + Coolant Fans Problem
Lawngoose
My pacecrappers don't hit.
Mine don't either. Must be a design flaw :th_thumbsup-wink:
Joe m
even the real ssac's haver issues that have to be fixed. my rear o2 is pushed into my body of the car. which is causing i notacble vibration when i start and drive. i think only weay to fix it is to cut the peice and twist it. oh and the damn ubend in the ssac's i didnt have tme to fix mine last night. and it drags over any little bump i have in my yard lol. if i was to run with no rear o2 till i got it tuned what would happen?
I'm not running an O2 because its arriving in the mail on monday
you get a check engine light and i think it screws your gas mileage up.
i went from 20+ MPG to like 13MPG
Your not running ANY o2 sensor? Ya that's good.
Spartangl
He's talking about the REAR O2 sensor, not the front one. Only an idiot would run without a front O2 unless it was tuned specifically for it.
Scimmia
its the rear.
i didnt buy the extension before i installed the headers.
and it arrives monday ish
You do not need an extension for the rear. You need one for the front.
Joe m
Dent the body of your car where it hits. It is not noticeable on the inside, and gives you the room you need.
01GTP
oh... lol well regardless i dont have the extension on it yet.
monday afternoon i will. i ordered it two+ weeks ago but it went to my HOUSE
And i just transfered to Miami so i had to get it sent here.
my MPG has been sucking recently other then that its been fine.
So you are not running with the front 02 then.
01GTP
whichever one needed the extension. drove from Tampa to Miami (about 5 hours) just fine. my MPG kinda sucks (normal 22mpg, to 14mpg) now. but i assume when i get the extension it would be just fine.
it has a code anyway cuz i took the cat out. . but thanks for the help!
i still haven't fixed my coolant fan issue.
going to remove the fan motor this week.
the ssac's need a front o2 extension the rear is fine. the ko pacesetters needed the front done aswell i believe.
all headers need the front extended
Scimmia
Right...but from my understanding of the thread so far and him saying he ISN'T running the one that needs the extension since he doesn't HAVE the extension...means he has been driving around without his front o2. I thought I had mine plugged in once but I guess it didn't snap in and came loose. He isn't joking I was seeing around 9 mpg's. Easy fix though...you can also just splice the wires you have and extend them down a couple feet and wrap them in exhaust tape or header wrap.
Just to throw crap in the fan my SSAC's hit the heat shield.
Lsick7
Do you have shortened dog bones or something? Mine have plenty of room.
i got stock dogbones.
[QUOTE=bluegtp91;330659 Easy fix though...you can also just splice the wires you have and extend them down a couple feet and wrap them in exhaust tape or header wrap.[/QUOTE]
i did this... works fine.
i also had 97/98 style fans on my car so they were bigger than the 99+ thin ones.
