Thread: FML, Help
Results 1 to 19 of 19
  1. #1 FML, Help
    Largo, Florida, United States
    On my way to Court around 3:30pm this afternoon
    I noticed my Temp was Abnormally high and rising. I pull over Immedently
    My coolant Hose below my Radatior came off, dumped my Dex cool out.
    so i let the car sit and cool down and then put some water in it and drive the Half a mile left to the court house, let it sit and go to court.
    3 hours later i had my freind bring me 2 gallons of Dex Cool. I fill it to brim, Crank the car and then continue to fill.
    then after like 4 mins of it running fine, the Supercharger starts making a weird sound
    i shut the car off. let it sit for a minute and then try to crank it again and it didnt wanna start and a Little bit of Smoke came from the Airfilter section.
    I'm going back in a few hours to see if i can get it going but does anyone have any useful imput?
  2. #2 Re: FML, Help
    Feb 2008
    Check your dipstick and see if there is coolant mixed in with the oil. Sounds like you may have ingested coolant.
  3. #3 Re: FML, Help
    Quote Originally Posted by DanGTP View Post
    If this was the case, what are my options?
  4. #4 Re: FML, Help
    Jan 1970
    Maquoketa, Iowa
    Something may have gave out and pressurized your coolant system, blowing off the hose.
  5. #5 Re: FML, Help
    Quote Originally Posted by FoSHO99 View Post
    any ideas as too what?
    i did the upper and Lower intake gaskets this weekend.
  6. #6 Re: FML, Help
    Willoughby, Ohio
    perhaps a LIM gasket leak?
  7. #7 Re: FML, Help
    well i just Changed the LIM this weekend.
    Im thinking its something to do with the fact all the coolant drained out?
    or maybe that i put water into it while it was hot?
  8. #8 Re: FML, Help
    GT Level Member rolyat's Avatar
    OKC
    sounds to me like a blown headgasket. Overheating then excessive pressure in coolant system usually equals headgasket, and now possibly a cracked block if you added the water when it wasnt running...
  9. #9 Re: FML, Help
    The Radatior hose was loose and came off and drained the coolant, then due to lack of coolant the engine temp rose.
    but since ive Reattached the hose and Tightened the hose clamp on snuggly
    and refilled dexcool
  10. #10 Re: FML, Help
    OKC
    Well all I can say is it was running good and it overheated... now its not running. So basically something was damaged due to overheating... could be headgasket, block, or intake gaskets even though you just did them.
  11. #11 Re: FML, Help
    Im going back in about an hour and going to try again
  12. #12 Re: FML, Help
    started back up just fine lol!?
    slight chip coming from the Supercharger Belt.
    other then that just fine.
  13. #13 Re: FML, Help
    OKC
    unless your hose was just really loose and came off. The noisy s/c might mean its warped from overheating?
  14. #14 Re: FML, Help
    Quote Originally Posted by rolyat View Post
    yeah it was loose, but any reason why a small amount of smoke would of came from the Air intake? or why it wouldnt Crank right and start?
  15. #15 Re: FML, Help
    Banned - Busted For Scamming
    Feb 2009
    Omg you got all worried because the belt got coolant on it and started making noise? Yea...
  16. #16 Re: FML, Help
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  17. #17 Re: FML, Help
    no it wouldnt start originally
    then i tried again a few hours later and it works.
  18. #18 Re: FML, Help
    It hates you
  19. #19 Re: FML, Help
    It hates you
    This feels true at times
fml
