Thread: Valve train questions
Results 1 to 20 of 21
  1. #1 Valve train questions
    SE Level Member whodat79's Avatar
    neenah
    i'm currently replacing my UIM and LIM and i figured i would update some stuff on the inside. So i looked into putting 1.9 rockers in and i was wondering if i need push rods and new bolts. Now if i go with intense package deal i get rods rockers bolts.... if i go this route do i need to update valve springs, retainers? thnks for reading hope u guys can help
    2000 GP GTP....
  2. #2 Re: Valve train questions
    you need new bolts, id the the ARP reusable ones.
    depending upon the ratio you may need springs and retainers.
  3. #3 Re: Valve train questions
    neenah
    so if i go 1.9 rockers kit from intense will the 90# springs work or 105#? same with retainers... what will work best zzp steel retainers or the modded steel?
    2000 GP GTP....
  4. #4 Re: Valve train questions
    GT Level Member rolyat's Avatar
    OKC
    I used L76 springs and retainers. They're cheap and will work just fine with a 1.9 setup.
  5. #5 Re: Valve train questions
    Portland Oregon
    You don't need the modded steel retainers, standard ls1 retainers will do. I'd go with 105's. They are easier on the timing chain damper
  6. #6 Re: Valve train questions
    neenah
    ok so ER 1.9 rockers from zzp with L76 springs and retainers from gmpartsdirect. is there ne thing to gain from installing new push rods? beside just replacing them cuz im already there!
    2000 GP GTP....
  7. #7 Re: Valve train questions
    OKC
    Do you have a gtp? If you're supercharged then you dont want the ER rockers, just the regular modded rockers.
  8. #8 Re: Valve train questions
    ER rockers are not 1.9s.
    you have no need to replace the pushrods.
  9. #9 Re: Valve train questions
    neenah
    yes it is a gtp... besides the $20 difference .... what is the difference between er and modded rockers?
    2000 GP GTP....
  10. #10 Re: Valve train questions
    neenah
    and will modded rockers work with L76 springs and retainers?
    2000 GP GTP....
  11. #11 Re: Valve train questions
    ER rockers have different ratio intake and exhaust rockers. you dont want that. yes, those springs/retainers will work.
  12. #12 Re: Valve train questions
    neenah
    thanks guys for your input its greatly usefull!
    2000 GP GTP....
  13. #13 Re: Valve train questions
    ER rockers are for better use in N/A cars. Should say that on ZZPwned's website
  14. #14 Re: Valve train questions
    neenah
    woops i read that er rockers were for n/a but forgot... as i was taking in a lot of info on my car! thanx for the reminder!! so i have purchased pacesetter header, modded 1.9 rockers and L76 springs and retainers along with rocker bolt!
    2000 GP GTP....
  15. #15 Re: Valve train questions
    Jan 1970
    Maquoketa, Iowa
    Your full list should be:
    1.9 modified rockers
    Re-usable rocker bolts
    Viton valve seals
    Valve cover gaskets
    Spring compressor tool
    Either a compression tester with air hose attached or something to keep the valves up when replacing springs.
    No need to replace pushrods or take them out, lifters should be fine also. You need "better" springs when running 1.9 rockers. At this ratio, stock springs may let the valves to float at higher rpm's.
    The rear bank is going to be fun to replace the springs on, you may want to do them with the engine tilted forward or attach the bracket on the front again and ratchet it forward or whatever way you can find.
  16. #16 Re: Valve train questions
    GTP Level Member
    Nov 2008
    MA
    Quote Originally Posted by whodat79 View Post
    should be a beast after those mods ^ quick question though..are you really running a 3.1 pulley at the moment??
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  17. #17 Re: Valve train questions
    neenah
    actually now that i think of it i think i think my sc pulley is smaller than 3". hopefully i get my parts this weekend and i'll give an update on how it went!
    2000 GP GTP....
  18. #18 Re: Valve train questions
    you need a scanner so you know what the hell is going on with your car. its literally impossible for you to be able to run a 3.1 or smaller pulley without a ton more work.
  19. #19 Re: Valve train questions
    MO
    whoa! read thread in my sig
    <brandonl2000> LMAO D!!
  20. #20 Re: Valve train questions
    ^^Agreed. To run a 3.0" safely you'll need a full-size IC, cam, rockers, injectors...and a tune etc.
  1. Valve Cover Gasket Replacement questions
    By BDEGhost in forum General Tech Discussion
    Last Post: 02-04-2010, 07:26 PM
  2. all aboard the bullitt train :)
    By gotboost3 in forum Tires & Wheels
    Last Post: 05-25-2009, 08:31 PM
  3. Drive Train HELP NEEDED
    By revivemylife in forum General Tech Discussion
    Last Post: 05-03-2009, 06:22 PM
  4. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
  5. Valve train questions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 05:59 AM
