Thread: Valve train questions
Results 1 to 20 of 21
  1. #1 Re: Valve train questions
    you need new bolts, id the the ARP reusable ones.
    depending upon the ratio you may need springs and retainers.
  2. #2 Re: Valve train questions
    SE Level Member whodat79's Avatar
    neenah
    so if i go 1.9 rockers kit from intense will the 90# springs work or 105#? same with retainers... what will work best zzp steel retainers or the modded steel?
    2000 GP GTP....
  3. #3 Re: Valve train questions
    GT Level Member rolyat's Avatar
    OKC
    I used L76 springs and retainers. They're cheap and will work just fine with a 1.9 setup.
  1. Valve Cover Gasket Replacement questions
    By BDEGhost in forum General Tech Discussion
    Last Post: 02-04-2010, 07:26 PM
  2. all aboard the bullitt train :)
    By gotboost3 in forum Tires & Wheels
    Last Post: 05-25-2009, 08:31 PM
  3. Drive Train HELP NEEDED
    By revivemylife in forum General Tech Discussion
    Last Post: 05-03-2009, 06:22 PM
  4. Boost Bypass Valve Questions....
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 08:25 AM
  5. Valve train questions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 05:59 AM
