Thread: Fuel line to fuel filter cracked need help asap
Results 1 to 7 of 7
  1. #1 Fuel line to fuel filter cracked need help asap
    Rockford, IL
    Went to replace the fuel filter and the line was rusted to crap an cracked on one turn. I cant tell where the line goes up to and obviously i cant take it in. How hard is it to replace? where exactly does that line lead up to? Any ideas or suggestions? Thanks
  2. #2 Re: Fuel line to fuel filter cracked need help asap
    Rockford, IL
    Someones had to replace a line sometime. I tried following the line from underneath even with the tire off but the lines cross i cant see a damn thing and now im wondering if its one solid line that leads to the fuel rail or does it meet another line by the firewall
  3. #3 Re: Fuel line to fuel filter cracked need help asap
    Topeka, KS
    I think it meets another line. I'd call you local dealership parts dept. and see what they have to say. You could just cut that cracked part off and put a rubber hose over it and patch it to the fuel filter with hose clamps for a temp fix. I just tried to look this up on alldata and they don't really show schematics. You'll probably have to call a dealership and get a new fuel line.
  4. #4 Re: Fuel line to fuel filter cracked need help asap
    Donating Users kfish's Avatar
    Ohio
    you realize you dont turn the nut on the line right? you hold that end and turn the filter....thats prolly why you cracked it.
  5. #5 Re: Fuel line to fuel filter cracked need help asap
    GT Level Member gpbastard's Avatar
    Florida
    Quote Originally Posted by kfish View Post
    not to revive an old thread but your tip about un-screwing the filter to get it off was a lifesaver. i had the classic can't get the filter off until i came across your thread and tried it and it came right off. i, like alot off other people didn't realise that's how you do it. a million thank's for a great tip....
  6. #6 Re: Fuel line to fuel filter cracked need help asap
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    I did the same thing with mine. I cmpletely twisted the fuel line shut trying to twist off the filter. I ended up cutting the fuel line and running a compression fitting. No leaks for 2 1/2 years. Worked out great for me. I just bought a piece of pipe and a fitting from autozone.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  7. #7 Re: Fuel line to fuel filter cracked need help asap
    Florida
    Quote Originally Posted by OrangeL67 View Post
    I almost felt your pain today doing mine filter. I thought it best to stop and research it on this forum and then i ran into kfish's eloquent tip....
  1. Fuel line disconnet
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2009, 08:22 AM
  2. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
  5. 04+ fuel return line
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 11:40 PM
