After....sorta.
Rough it in, cut down as far as you need to, then after you've broken through the housing, put the JB weld down in the crevice from the outside, smooth out. If you're going to build a "ramp" up to the MAF sensor, do that after as well, and then smooth the whole thing out with an 80 grit flapper, then go up to a 120.
