Thread: heat spike
Results 1 to 20 of 31
  1. #1 Re: heat spike
    Donating Users blowfishRus6's Avatar
    g.a.
    air pockets will cause heat spikes like that.
    i just let the car get up to operating temps, crack the radiator cap for a few mins, let it bleed the air out, then cap it back up.
    you dont even need fans if you have a properly working coolent system. well maybe on a 100* day sittin in traffic, but even then it should not OVER heat, just run hot.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: heat spike
    Feb 2008
    San Diego, CA
    Glowing red exhaust manifold usually means either plugged cat (as said), running too-retarded timing or poor valve seating (allows unburnt fuel to combust in exhaust manifold), or running too lean (just gets too hot).
    As was said, since it's only one pipe, it's likely not a cat (or for that matter, timing) issue. I guess it could be a bad injector on that cylinder causing leanness, but then you said the problem went away?
    (Injectors can have intermittent issues, of course)
    And since it did "go away", it's probably not a valve issue.
    I'm with those who think it was an air pocket/bubble in the coolant jacket in the head, and it's probably OK (burped itself) now.
    But do burp it, keep an eye on it, and keep an eye on that cylinder's injector. If you see redness on that cyl again, switch injectors around and see if the problem follows.
  3. #3 Re: heat spike
    GT Level Member undecided's Avatar
    taylors falls MN
    thanks ill try that this weekend
    1998 white grand prix gtp - speed daddy headers & ported supercharger
    1982 z28 Camaro - all original with only 80k miles and rust free - slow as heck
  1. Low heat
    By citydriver in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2010, 08:20 PM
  2. No Heat, Need Help.
    By speed24 in forum General Tech Discussion
    Last Post: 12-17-2009, 03:50 PM
  3. No Heat!
    By srspicer in forum General Tech Discussion
    Last Post: 10-25-2009, 11:55 PM
  4. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  5. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
