Thread: Boost gauge reads zero
Results 1 to 7 of 7
  1. #1 Boost gauge reads zero
    SE Level Member COEBAM's Avatar
    LAWRENCE KS
    Hey guys- I did a little looking around about this, and found some threads, still not sure. The gauge lights up just no reading. Does the MAP sensor feed this gauge or is it the vacuum line off the by pass valve? If it is the valve; where is the bypass valve located?
    Btw got the coupler kit put in and a new SC belt and tensioner works great. Just trying to fine tune a few things...Thanks everybody!
  2. #2 Re: Boost gauge reads zero
    Outer Space
    I installed a plastic vacuum line T to tie into the vac line at the MAP sensor. Should read in the negatives on idle.
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Boost gauge reads zero
    depends what kind you got. did you get an digital or analog gauge?
  4. #4 Re: Boost gauge reads zero
    LAWRENCE KS
    It's just the stock gauge located in the info center.
  5. #5 Re: Boost gauge reads zero
    that is read through the PCM, so id say you have a vacuum leak or your BBV is done for.
  6. #6 Re: Boost gauge reads zero
    LAWRENCE KS
    Found a vacuum leak under super charger at the little tee. Thanks everyone!
  7. #7 Re: Boost gauge reads zero
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    go ahead and replace crappy looking lines. i had several that were unnoticed for a while.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. Need a Boost Gauge
    By SDGTP99 in forum General Tech Discussion
    Last Post: 09-27-2009, 08:20 PM
  3. Boost Gauge?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:56 PM
  4. Boost gauge...
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 08:52 PM
