Thread: Time for a tune?
Results 1 to 20 of 33
  1. #1 Time for a tune?
    Nov 2009
    United States
    Allright I am getting ssac headers with in a week or so but was woundering if i can drop down to a 3.4'' puelly safley or would I need a tune in order to do this? and my plan was to get a tune when i get different rocker arms (which was my next step). and the mods I have now is a cooler set of spark plugs, 180 degree thermostat, cold air intake, and a 3.5'' puelly
  2. #2 Re: Time for a tune?
    Donating Users kfish's Avatar
    Ohio
    youll need a tune after the headers
  3. #3 Re: Time for a tune?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    u dont need a tune for the headers right away but definetly wouldnt hurt to have it done
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  4. #4 Re: Time for a tune?
    you wont run that 3.4 (even with the headers) if you dont get a tune.
  5. #5 Re: Time for a tune?
    Aug 2008
    Long Island, New York
    if you plan on dropping to a 3.4 your gonna need a tune
  6. #6 Re: Time for a tune?
    Donating Users blowfishRus6's Avatar
    g.a.
    are you running the 3.5 pulley right now with no tune????
    and i dont see what the diffrence between a 3.5 and a 3.4 is, its maybe 1 more pound of boost. you could always just up the timing some to make up the diffrence.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: Time for a tune?
  8. #8 Re: Time for a tune?
    Yay for a pulley drop on a car with stock exhaust!!
  9. #9 Re: Time for a tune?
    Apr 2009
    stockton ca
    Stupid question I know but Why dont you wait to install the headers till you do the rockers since it al has to be apart anyway then get a tune drop to a 3.4 and call it a day
  10. #10 Re: Time for a tune?
    Jan 1970
    Maquoketa, Iowa
    Get in touch with a tuner now, let him know your plans. I would get a base tune on after the header install and get you kr free. Then have him do a better tune when you get the rockers on.
    If they want to charge you an arm and a leg to do that, see if you can at least get a scan or buy a scan guage until you do the tune.
  11. #11 Re: Time for a tune?
    Pffft. I'd rather keep the 3.5"...install the headers/rockers...and crank hte timing as much as you can. It isn't alawys about smaller pulleys...its about flow and timing.
  12. #12 Re: Time for a tune?
    no, its about more boost. duh. thats how my car always ran, low timing and high boost.
  13. #13 Re: Time for a tune?
    I tried that concept...you know what happened
  14. #14 Re: Time for a tune?
    Aug 2008
    thats what im going for with my meth injected build coming after the winter
  15. #15 Re: Time for a tune?
    And hows lower boost higher timing working out?
  16. #16 Re: Time for a tune?
    Low boost, high timing...
    or
    High boost, low timing.
    Either or, its your option...you can make more power with the bigger pulley and more timing because there is less heat and less parasitic loss from the blower. On the flip side, more boost makes up for the power of the higher timing on the bigger pulley setup...make sense?
  17. #17 Re: Time for a tune?
    or
    Basically comes down to stress. Got it.
  18. #18 Re: Time for a tune?
    g.a.
    less heat more timing
    its slow.
  19. #19 Re: Time for a tune?
    Banned
    oswego
    well actually, with a 3.5, header car, intake, basic bolt on, and tuning (someone that knows their stuff) could smoke the average 3.4 setup. My DD (when it was stock of course) trapped higher than most modded gtp's do with bolt on's, which was 98.7mph, or almost 99mph... just saying... The power isn't in the pulley size, it's in the tune. It's unfortunate that people think the smaller pulley they run will make them faster, it's not anything like that. The smaller pulley will make you think the car is faster because of the added tq, but when it comes to a 50mph and higher race, it's over.
  20. #20 Re: Time for a tune?
    g.a.
    Quote Originally Posted by Mikegotone'02 View Post
    dropin knowledge.
    its slow.
  1. Tune Up Time
    By GPSims39 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-28-2009, 10:19 PM
  2. tune
    By badbrad in forum General Tech Discussion
    Last Post: 03-18-2009, 10:29 PM
  3. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
  4. Anyone want to tune near MD?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-13-2008, 10:00 AM
  5. Getting a tune done.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-15-2008, 01:50 PM
