Thread: Fuel Pump or Filter?
Results 1 to 20 of 30
  1. #1 Fuel Pump or Filter?
    Michigan
    O.k I asked the question about fuel pump of filter? I changed both and the car still stalls out! It will start and run for a few and then it stalls out but it will start right back up and then stall, I have a supercharger 1997 Grand prix Could it be the fuel pump regulator and if so how do I troubleshoot it and where is it located?
  2. #2 Re: Fuel Pump or Filter?
    Wooster, Ohio
    lol, well i'm having the same damn issue as you and i've got a scope on mine currently, you make any progress let me know and i will do the same for you. It is although NOT the fuel pump in my case, The fuel pump is running in severe duty and the car is running lean as hell
  3. #3 Re: Fuel Pump or Filter?
    Wooster, Ohio
    i was gonna replace my filter just because and i twisted my line off even though i heated it first...so yea i'll let ya know more when i get some fuel line back on here
  4. #4 Re: Fuel Pump or Filter?
    Michigan
    I'm going to clean the mass airflow sensor tomorrow and see if that fixes the problem.Hey Pittman! Any luck with your car?
  5. #5 Re: Fuel Pump or Filter?
    Aug 2008
    Pennsylvania
    Hey my car sometimes stalled. So i was too cheap to buy a MAF and so i bought a new gas filter. When i took it off the old one was VERY plugged. This helped a little but the care still didn't run like it was so post to. I than finally bought the MAF. That was the answer. Do both and if they don't work than maybe its the fuel pump but, im not all that educated with cars so thats a guess. Best of luck
    I Always Need Help
  6. #6 Re: Fuel Pump or Filter?
    Michigan
    Yeah I already changed the filter and fuel pump no change, I cleaned the MAF no change. I'm not saying the MAF that I have on there is good but it all boils down to is me buying a new MAF.
  7. #7 Re: Fuel Pump or Filter?
    Wooster, Ohio
    I also did my filter and very little changed, talked to a old gp junkie tonight and he said its basically 90% gonna be the crank sensor, and it will not throw a code because when it malfuntions it shuts down right away and doesn't have time for the pcm to register the issue.
  8. #8 Re: Fuel Pump or Filter?
    Aug 2008
    Pennsylvania
    With my maf i cleaned it real good and there was no change. I had to buy a new one.
    I Always Need Help
  9. #9 Re: Fuel Pump or Filter?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    any progress yet??? curious.
  10. #10 Re: Fuel Pump or Filter?
    Nov 2009
    Grand haven
    On the 97 gtp I had the same prob and it was the fuel resistor. It is in the front pass side bumper cover by the pisser fluid bottle. Let me know what you find.
  11. #11 Re: Fuel Pump or Filter?
    manhattan
    Quote Originally Posted by shawngtp View Post
    I agree. I had the same problem on my 99 gtp and a fuel pump resistor fixed it.
  12. #12 Re: Fuel Pump or Filter?
    Wooster, Ohio
    on this resistor is it dealer only? or is it just a generic resistor you got from radio shack or something? Also is it mounted somewhere or inline in the wiring?
  13. #13 Re: Fuel Pump or Filter?
    Michigan
    Well I put a new MAF on and guess what? Same thing! Car starts and then stalls out, so far I have a new fuel pump, fuel filter and MAF sensor and now I'm really confused. Anybody have any ideas?
  14. #14 Re: Fuel Pump or Filter?
    Donating Users Warbeaver's Avatar
    St. Louis
    well, based on what others have said, you can try the crank sensor or fuel pump resistor
  15. #15 Re: Fuel Pump or Filter?
    westfield ma
    I just went thru this problem, I had another post asking the same questions. They allhad me check and change sensors, fuel pump,fuel filter. My brother found a post here of a car that would start and run only if tapping the throttle to keep rpms @2000- 4000. The problem was fuel pump resistor. quick fix bend tab on # 15 fuse and start up. worked like a champ. hope it helps jim
  16. #16 Re: Fuel Pump or Filter?
    Wooster, Ohio
    you mean bend tab as in take the #15 fuse out of the picture
  17. #17 Re: Fuel Pump or Filter?
    Wooster, Ohio
    found it, you bend out the #85 tab on the fuel pump resistor relay, which is in the #15 position, heres the pic i found and i'm about to go try this
  18. #18 Re: Fuel Pump or Filter?
    westfield ma
    I followed the pics from post and and it worked. I found a site that there is a recall and a new kit that moves it from under wheel well to fire wall
  19. #19 Re: Fuel Pump or Filter?
    Wooster, Ohio
    ^This just fixed my problem!!
  20. #20 Re: Fuel Pump or Filter?
    westfield ma
    now we just have to get a new resistor kit. Thanks to all who helped me . This is a great site
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Pump or Filter?
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2010, 11:13 AM
  3. Fuel Pump or Filter?
    Last Post: 01-18-2010, 11:12 AM
  4. Oil Pump/Filter Assembly
    By Randomx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 04:25 PM
