Thread: 9.11 lbs of boost with stock pulley?
Results 41 to 60 of 68
  1. #1 Re: 9.11 lbs of boost with stock pulley?
    Wausau, WI
    Quote Originally Posted by xxmattfxx View Post
    My car is mostly stock and have been battling high amounts of KR (5-8*). I know that the original pulley is still on there, but notice through my scan that at WOT I have gotten up to 9.11 lbs. of boost. I believe this is related to the high KR and was wondering what other factors that could occur over time would increase boost to that level. From what I have read, stock pulley usually generate between 7-8 lbs.
    Our cars differ greatly in boost measurements with the same pulleys. Some people claim to have a max of five pounds boost with the stock pulley and some record 9....I was one who had nine pounds of boost on stock pulley, however I had no knock and no mods at the time...this has been discussed many times and there are no measurements that are the same boost wise on our vehicles...it is just an approximation of how well our intake/motor/exhaust flow together everything considered unless something is way out of line.
  2. #2 Re: 9.11 lbs of boost with stock pulley?
    GTX Level Member JoelW98GTP's Avatar
    Nov 2009
    Portsmouth, OH
    Talk about a hijacked thread! Poor OP. I think this one might be showing some change for the good in street.
    98 GTP - Autolite 104s, wires, 180* t-stat, fwi, catless dp and plog, glasspack res, Reptile tuned PCM, tinted tails.
    91 Toyota MR2 Turbo - 327RWHP 322RWTQ 11.48@122mph
    03 BMW 325i - tint. stock.
  3. #3 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    Apparently i post false info, so here's the truth. You're running wayyyy to much boost, you should get a bigger pulley so you can get down to 7-8lbs of boost ASAP or your 5-8* of kr WILL blow that engine up! I'm surprised that you haven't thrown 3 pistons straight out of the hood man. Also something to consider, you could go get it tuned by zzperformance.com, they are the best tuners out there. Or you can go to INTENSE-RACING.COM They are the leaders in 3800 specialties, they should be able to take care of you!
  4. #4 Re: 9.11 lbs of boost with stock pulley?
    Quote Originally Posted by Mikegotone'02 View Post
    Still isn't the credible info people are looking for you sarcastic know it all.
  5. #5 Re: 9.11 lbs of boost with stock pulley?
    Wausau, WI
    so your answer is either to get it tuned by zzp or get a smaller than stock pulley? Here is an idea: find out what is causing the knock and fix it. There is no way short of a terrible tune( i.e. advancing the timing through the roof) that you should have that much knock with a stock pulley. Find what is causing the knock(or if a sensor is bad) and fix it. And for the record zzp might do ok with custom tunes, but they have been known to blow motors with their canned tunes for our cars, so I would stay far away from them for tunes. They just cut it too close to be safe, IMO...
  6. #6 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    Quote Originally Posted by Liquifire View Post
    Let me go back to pre-school where i was taught to read, and go over what i said. I believe it was a BIGGER pulley, not a smaller one. I'm suggesting the leaders in 3800 performance, these guys know what they're talking about. They are the best of the best, this is where HORSE POWER is made. You want a kr free tune you need to see the masters! This forum will agree, intense or zzp, are the best that will ever be! Get a tune man! 3.4 pulley will make make hp/tq with the best tune ever!
  7. #7 Re: 9.11 lbs of boost with stock pulley?
    Donating Users kfish's Avatar
    Ohio
    ive got 2 good knock sensors ill sell if you want to try them.
  8. #8 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    i'm trying to help my fellow 3800 friends tackle their problems. 9.11lbs of boost is just wayyyyy to much, i couldn't sleep at night knowing this car is making that kind of boost. His bottom half of his motor is probably on it's last leg holding power like that, it's just not safe. If he wants to be safe he needs to go our leaders in 3800 technology, he needs the best, he needs zzp/intense-racing. That's where winners get their trophy's, that's where losers are turned into winners! Lets win, lets get a race tune! 3.8 pulleys are for slow 3.8 cars!!!!!
  9. #9 Re: 9.11 lbs of boost with stock pulley?
    Ohio
    thats too much? i have 15-16 psi, my bottom ends just fine
  10. #10 Re: 9.11 lbs of boost with stock pulley?
    Topeka, KS
    Quote Originally Posted by kfish View Post
    For the record I was running 14 to 14.5 #'s of boost before my header install this weekend with 0* of KR on a 3.4 pulley.
    Now that the headers are on I am running 11#'s of boost with a 3.25 and 1* of KR that will be tuned out in the near future.
  11. #11 Re: 9.11 lbs of boost with stock pulley?
    MO
    "hmmmm hmmm hmm we didn't start the flame war... hmm hmm hmmmmm hmm hmmmmm"
    <brandonl2000> LMAO D!!
  12. #12 Re: 9.11 lbs of boost with stock pulley?
    Quote Originally Posted by ZR1Vette09 View Post
    Someones spends too much time on the internet... wait... ****...
  13. #13 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    15 psi? Wow!!!!!!!!!!!!!!!!!!! You must have factory forged internals, that thing should be blown up man! You must have a professional tune on that sucker, cause if any other 3800 saw boost like that it would be in the ruins!!! I would see that bad boy in the junk yard, still smoking after it's chipped pistons and spun bearings! Wowowowow!!! 15lbs!!! man! that's just smokin' fast!
  14. #14 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    There's some race-cars in this thread!!! op's drivin' a FAST bonne!!!
  15. #15 Re: 9.11 lbs of boost with stock pulley?
    Ohio
    it is a professional tune, and no, stock internals, with 0 knock
  16. #16 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    Wow STOCK??! Man, if i was running 15psi that would be a ticking time bomb for my car, i'm running a stock bottom end. It's just not meant for power like urs, it's meant for my car which is only on 4psi, it's safe there. I make almost 220whp with a 50shot of NITROUS!! I hope my trans holds my power, which for the op is questionable. Talk to our leaders in transmissions, he'll get you a trans that will hold 9.11psi!!!
  17. #17 Re: 9.11 lbs of boost with stock pulley?
    Ohio
    here ya go. watch it
  18. #18 Re: 9.11 lbs of boost with stock pulley?
    Okay now you're just sh*t posting, and believe it or not, there should be a rule against it because its just a complete waste of a post in an already hijacked thread.
  19. #19 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    wow, i just have a stock bottom end from some buick car, running a 2.8 pulley on a gen v, I can't touch boost like that. The last scan i looked at from my car was 200kpa at 4k, i think that's like 4psi, maybe 5? I'm not good at converting!
  20. #20 Re: 9.11 lbs of boost with stock pulley?
    Banned
    oswego
    This is a little off topic, i'm sorry!!! I'll go back to the op's question, which i answer with getting a PROFESSIONAL tune!!! ZZP all the Way!!!!!!!!!!!!!!!!!!
    Sorry for getting a little off the road there man!!! Soooo sorry!!!
  1. Pulley size vs. SC vs. boost
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 07:12 PM
  2. max boost with 2.9 pulley?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2008, 10:32 AM
  3. How much boost with a 3.4 pulley?
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:21 PM
