Thread: Plugs burnt/bent and 27* knock!
Results 1 to 20 of 55
  1. #1 Re: Plugs burnt/bent and 27* knock!
    Apr 2009
    stockton ca
    if you had bent plugs then more then likely your pistons are chipped or something got in there i would also do a compression test to see what psi's look like
    burnt plugs mean it got real lean and real hot
  2. #2 Re: Plugs burnt/bent and 27* knock!
    This could be a simple vacuum hose. Typically they won't show up as a code etc until it's a huge leak. I agree with Wicked about the plugs. it's not good.
    Being at 17 AFR when coasting is completely normal. When you are on the throttle, that's when it would be bad.
  1. My radio hates my Burnt cds
    By reffer101 in forum Audio, Security & Visual Electronics
    Last Post: 12-11-2009, 11:50 AM
  2. Bent rims
    By rocafella2032 in forum The Rant Forum
    Last Post: 06-20-2009, 12:31 AM
  3. Question:Cradle bent, Lower Arm....
    By mikes_comp_g in forum Brakes/Suspension/Chassis
    Last Post: 04-14-2009, 10:29 AM
  4. rear O2 for U bent delete
    By SofaKingCdn in forum General Tech Discussion
    Last Post: 10-04-2008, 08:59 PM
  5. Transmision fluid burnt. Do i flush it?
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 09:13 PM
