Thread: Chipped pistons options
Page 7 of 8 FirstFirst ... 5678 LastLast
Results 121 to 140 of 153
  1. #121 Re: Chipped pistons options
    no, it should not be pegged under light acceleration. a real boost gauge would help more though.
    scangauges: aeroforce or scanmaster.
  2. #122 Re: Chipped pistons options
    Fort Atkinson
    Scanmaster? nevermind searched it......**** its more then the scanguage. So is ZZp the cheapest for the scanguage?
    Could this be a boost bypass valve issue? I don't even know what pressure they are good for stock? I guess i should be searching the ish eh?
  3. #123 Re: Chipped pistons options
    unless the BBV is getting stuck closed then i dont see how that could be causing it. pop the hood and see if the diaphram moves when you goose the throttle.
  4. #124 Re: Chipped pistons options
    Fort Atkinson
    drive by wire FTL. OK well I goosed it and my boost guage is jumping up, damn near pegging so I got a problem for sure. The diaphragm linkage is all the way up, I can push it down,but can't see if it's moving from in the car. Damnit
  5. #125 Re: Chipped pistons options
  6. #126 Re: Chipped pistons options
    Fort Atkinson
    phone a friend.
    I have no friends....well not around here. OK this is what I see, the actuator moves down when the ignition is turned off, it goes up at startup. If I push it down while idling it starts making some racket. I'd assume it's working? or should I just bypass the solenoid and run it off vaccum once?
  7. #127 Re: Chipped pistons options
    bypass it for a sec and see what it does. dont leave the line open and create a vacuum leak cause then itll run like crap for sure.
  8. #128 Re: Chipped pistons options
    Fort Atkinson
    ok I'll try that tomorrow, went for another ride and the boost appears to be under control better,but will still verify the actuator operation is correct.
    I pinpointed my noise my trans is whining like a *****, especially in 1st. well off to work for me. Thanks for the help bio
  9. #129 Re: Chipped pistons options
    Fort Atkinson
    well a little update with the GTP if anyone gives a ****.
    Trans whine was from fluid, ended up adding a few more quarts to get it at full while running. It's been awhile since I worked on a car that needed to be running to get the proper fluid level...OOPS
    Boost appears to be fine as I can drive it around and stay out of boost with no problems. I think it was a freak occurance when it pegged under light load.
    I finally got a code and of course I'm back to misfire on cyl #3. The plugs are brand new and the wires are less then a year old. So, I picked up some new coils and reset the computer. About to go on another long drive to see how it responds.
    Being that this car has 115K miles on it, coils seemed like a good start. Are there any known ways to test them? My misfire only comes on under moderate load/boost. I can actually do short bursts of acceleration at times with no misfire sensed or felt. I still need to find/order a scanguage to monitor this thing better.
  10. #130 Re: Chipped pistons options
    some of these cars like to have misfire issues for no reason. it could be anything in the electrical system or even a chipped piston. i know mine misfired at idle all the time, but never when i was driving around (didn't have a cam either).
    i would have swapped the coil packs first to see if the misfire moved. if that didnt work i would have swapped injectors to see if it moved then. its possible that youre getting an injector that is dying.
  11. #131 Re: Chipped pistons options
    Fort Atkinson
    You're right I was thinking that when I changed out the coil packs "maybe I should just swap them first" But, then I said **** it the damn car is a GM and it has 115K miles on it.
    I went on a longer drive and the misfire is still there under load. At idle it's smooth, actually pulls decent below 3500rpms, but once you start getting around 3-3500rpms it becomes evident something is amiss. I was thinking injectors also. I'll swap the #3 injector and see what happens with the misfire then.
  12. #132 Re: Chipped pistons options
    Fort Atkinson
    I put the OEM coil packs back on and swapped #3 and #5 injectors. I still get a #3 misfire. I'm going to swap around the coil packs and pray tonight. I'm getting a bit frustrated now. Oh and any attempt at going above 3500rpms is met with severe bog and then eventual knock.
    On edit: I went through all the plugs and gapped them on the tighter side, verified all the wires are intact and seated. No noticeable improvement was felt. Also would cause the supercharger to flutter while under boost? It literally sounds like its fluttering on and off very quickly, not like the usual consistent whine. I'm going to see if one of the local dealers will do me a favor and check this thing out. I'm lost right now especially after the injector swap had no change. I'll try the coils again and see if it improves, if not I might just man up and take it to the dealer to get it scanned.
  13. #133 Re: Chipped pistons options
    for some reason it sounds like you have a clogged cat. im not reading back to read your mods or what youve done, but no power and bogging is usually a restriction in the system. is it making excessive boost and knocking?
  14. #134 Re: Chipped pistons options
    Fort Atkinson
    The problem is it actually pulls pretty good til I hit 3000-3500rpms, then it bogs down, loses power and eventually knocks(which I did twice and said enough of that) The car is bone stock outside of the L67 pistons and ARP rod bolts it is all OEM.
    Also are these cars susposed to stop revving at 3500rpms in park? I was slowly revving it up last night in the driveway listening for unloaded noises and noticed it just stops revving.
    I still need a real boost gauge and that scan gauge would be great too for troubleshooting purposes. Basically the symptoms are it can't rev past 3500rpms,begins to misfire around 3000rpms under load,will knock if I just keep trying to accelerate, the trans also gets finicky between the 1-2 shift when this is going on.
    I guess pulling my cat is the next option.....great
  15. #135 Re: Chipped pistons options
    yeah, we have a rev limiter in park and neutral when not moving. its somewhere in the 4000 RPM range.
    honestly i would invest in a 3" downpipe just because it opens up the car so much in comparison to stock and if your cat is clogged then youll be solving the problem at the same time.
  16. #136 Re: Chipped pistons options
    Fort Atkinson
    OK good to know.
    I was looking at the ZZp off road downpipe. With that I'll need the O2 simulators,but no more cat worries. I'm gonna drop the cat today or tomorrow when time permits. Any suggestions on a downpipe are greatly appreciated.
  17. #137 Re: Chipped pistons options
  18. #138 Re: Chipped pistons options
    Fort Atkinson
    OK I'll look into the 3" offroad pipe w/O2 sims and appriopate bungs for my 04. I guess I should have just got headers from the get go
  19. #139 Re: Chipped pistons UPDATE!
    Fort Atkinson
    Well I finally got the cat pipe dropped and found it full of aluminum Once i saw this I knew what my problem was, so I gutted the bastard. After a thorough gut job I bolted her back up and went for a drive. She breathes once again. No more supercharger flutter, no more misfire, no more revving problems. Amazingly it sounds good too, not much louder then stock which was a pleasant surprise. Now just to take care of the SES light and continue breaking it in.
    Thanks again Bio for the help
  20. #140 Re: Chipped pistons options
  1. Are my pistons screwed?
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 01-14-2010, 04:41 PM
  2. installing pistons in the l67
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2009, 04:45 PM
