nothing better than carnage pics!!!!! reminds me of me
Morad still has no L32 pistons,but has plenty of L67 pistons. 6 for $100 so I'll be buying some from him in less something pops up in the next few days.
Ok so is the ZZP engine overhaul kit all Felpro stuff? Price looks good at $219 with head gaskets.
I might be able to beat that at Oreilly with a friends employee discount. Also going to look into a ring set, main and rod bearings. Hopefully the discount will be enough that I can weasel the headers into the mix.
Any other little things I should be doing? gasket matching? any porting or cleanup work? lap all the valves in/de-carbon them.
how would you know if you had this problem?
L67 Pistons/rods came in last week from Morad. They are currently soaking in parts cleaner to be decarbonized.
I also ordered main bearings,rod bearings,piston rings,complete engine gasket kit,assembly lube and coolant elbows from ZZP. I can't get employee dicount at oreilly anymoreSo it looks like no headers for this rebuild.
Planning on getting all the pistons cleaned over the next few days and then starting on the heads. The heads will be decarboned and the valves lapped in.
Any assembly suggestions are welcome/wanted.
Everything cept the rotors.
LOL,the rotors ironically are new and not tooo badly surface rusted yet. Pistons are cleaning up remarkable well. Are the L67 pistons susposed to be bare or coated also? The skirts and top are coated on the ones i got from Morad.
I'm going to be scrubbing everything down including the nasty ass engine bay.
the rotors in the S/C are what I was referring to.
