Thread: Finally getting some maintenance done. Help on list.
Results 1 to 17 of 17
  1. #1 Finally getting some maintenance done. Help on list.
    GT Level Member Black18Ice's Avatar
    Iowa
    Ok so I have a few weeks off from school and I want to get some work done on my car. Here is a list of things I want to do and what I am buying. Let me know what else I may need or should do.
    -Need to see where coolant is leaking. Make sure it is just the lim or uim
    -Coolant flush (going green)
    ..........-180 not drilled thermostat and gasket
    ..........-flush kit and coolant
    -Replace LIM
    ...........-Aluminum lim gasket and black rtv
    ...........-Supercharger gasket (unless I can remove it all together)
    ...........-2 o-rings (should I have them filled and adjust for the rear head coolant flow?)
    ...........-6 injector o-rings
    ...........-2 coolant elbows
    -Flip dog bones while I'm in there.
    -Replace coupler maybe (going to have it ported later so might wait)
    -2 oil changes
    -Maybe plugs and wires later
    -Smooth out valve covers
    ............-Paint, but idk what color. Probably black with red or silver lettering
    ............-Replace gaskets
    I think that is about it for now. Hopefully I can find enough money to do it all lol. I also hope it isn't my head gasket leaking. So many more things on my list too.
  2. #2 Re: Finally getting some maintenance done. Help on list.
    utah
    could also be that god damn little elbow going from the block to the tensioner
  3. #3 Re: Finally getting some maintenance done. Help on list.
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    maybe new belts while ur at it, also since alt. will be off, throw a voltage booster on there.....
  4. #4 Re: Finally getting some maintenance done. Help on list.
    Iowa
    Well the supercharger belt is already new. I will check the other one and the votage booster.
  5. #5 Re: Finally getting some maintenance done. Help on list.
    PA
    O2 sensor, metal idler pulleys, water pump, heater hoses, lower rad hose, upper rad hose, PCV valve, air filter, fuel filter, both fuel injector o-rings, valve cover gaskets, SC fluid,
    2001 GSE
  6. #6 Re: Finally getting some maintenance done. Help on list.
    Iowa
    I have some exhaust work to do, so I will do the sensor then. The pulleys are already replaced and no money for some of those things but I'm trying to get all I can.
  7. #7 Re: Finally getting some maintenance done. Help on list.
    Dec 2008
    hueytown, alabama
    my opinion is to get a denso brand o2 sensor for the top o2 sensor(most accurate, better than bosch) otherwise zef covered it very well
  8. #8 Re: Finally getting some maintenance done. Help on list.
    PA
    Also, transmission fluid and filter replace.
    2001 GSE
  9. #9 Re: Finally getting some maintenance done. Help on list.
    ^^And use Dexron VI...not that Dexron IV crap. Might as well make a shift kit too while your in there...someone has a write-up on CGP about it...but since that site is full of flaming...I stay far away...no need for that crap.
  10. #10 Re: Finally getting some maintenance done. Help on list.
    Iowa
    Should I use the chemical flush kit or just use water to flush my coolant system?
  11. #11 Re: Finally getting some maintenance done. Help on list.
    PA
    Quote Originally Posted by Black18Ice View Post
    If you are on a budget, water. The chemical kits work well I guess. But I never saw the need to use them.
    2001 GSE
  12. #12 Re: Finally getting some maintenance done. Help on list.
    Charles City, IA
    The chemicals clean a lot out. I use them in every flush at work.
    SMGPFC Two Nipple General
  13. #13 Re: Finally getting some maintenance done. Help on list.
    GTX Level Member Deimos's Avatar
    iowa
    I like using machines for flushing coolant you actually do a full flush.
  14. #14 Re: Finally getting some maintenance done. Help on list.
    Iowa
    It cost around 100 bucks to do a flush around here, so I'm going to save the money.
  15. #15 Re: Finally getting some maintenance done. Help on list.
    Jiffy Lube is like 50 bucks around here...but like recommending them is like wanting to have a guy with tourettes do open heart surgery on you.
  16. #16 Re: Finally getting some maintenance done. Help on list.
    Iowa
    haha Ya I called them today and they said 118. I know they are usually cheap because they suck.
  17. #17 Re: Finally getting some maintenance done. Help on list.
    Donating Users blowfishRus6's Avatar
    g.a.
    i stick a water hose in the radiotor and turn it on full blast. does a pretty good job. and then pull the thermistat out and do the same to the block.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  1. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
  2. What happens when you dont keep up with maintenance?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-03-2009, 06:32 PM
  3. Low maintenance mods.
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-13-2008, 04:15 PM
  4. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
  5. Dodge Dakota Maintenance
    By TyroElite in forum Off Topic Discussion
    Last Post: 01-28-2008, 09:29 AM
