Okay I just installed my VS with 3.3 pulley, 3 inch DP with No cat, No res. 2.5 inch pipes back to stock Y and stock Mufflers, SSAC Headers 104's and drilled 180 t-stat. HOLY SH!!!T IT SCREAMS. I'm very happy with the results. I have a custom tune from Big worm's performance shop. One of his GTP's runs mid 13's and mine is Clearly faster from any roll or a dig. I can't wait to get to the track and see what it does!
That sounds pretty good. I want to do this cam as well. What idle have a lot of you guys set it at for a nice sound?
there is actually not alot of people that run that cam. so you might not get to many replies on that.
but if your custom tuning, just play with it till you find the idle that you like.
Ask SlowM90, she runs/ran this cam.
Thanks. Just one more thing I was wondering while we are on the VS cam topic. When installing the cam, do I need to have a custom tune before running the car/driving it or can the car be driven after the install with no tuning? The reason I ask is, I would probably go to Will/Overkill for tuning, assuming I could get a hold of him, but he's a couple hours from me atleast. I can't do it any time soon this year unfortunately, but it's good to research.
I think I had mine set at 650 and it sounds mean as hell !!
Here is a video with headers, no cat no resonator back to the stock Y- split with the stock mufflers
http://www.youtube.com/watch?v=O98YEMl8zK4
I ran the car with no tune, 3.3 pulley and 90# springs for about 4 days and it was really impressive. It sounded great and performed like I wouldn't imagine. But after I took it back to clear a couple codes and tune it, ALL HELL BROKE LOOSE. I was more than happy with no tune, but tuning it helps you stay in the cam's powerband. There is a HUGE difference. I got my shift points set at 6200 and my AFR tightened up, and we wont even talk about the skip shifts... Holy..
Here is a vid of my first day with it with no tune. The tourque is rediculous
YouTube - My Grand prix GTP 25-50 Pull (Lost traction for a second)
and the xp does not even put out that much more max hp than the vs. they can put out very simular numbers.
s1x > VS > XP
but, id rather go custom and as big as i can go without destroying things in the process. small cams are boring and work better with turbo cars. if i were to make a cam right now for an m90 car it would be a similar design to a NIC, except much bigger.
VS cam looks like the one I'll go with. Good info guys. Thanks OrangeL67 for posting the vids that sounded awesome![]()
Hey no problem! So far i have taken down a 2010 Stang GT. New v6 camaro, Ls1 firebird (that firebird was a beast) and an ls1 vette (until about 3rd gear when he started haulin @ss like crazy) and countless ricers!If you get headers, I'm positive you won't be dissapointed
Thanks. Went through this thread sometime ago trying to decide the difference and what I wanted to get.
Sent using Tapatalk.
Zombie thread! Wheres my shotgun?
