Thread: 06 GT 3.8 sc series III better mpg?
Results 1 to 7 of 7
  1. #1 06 GT 3.8 sc series III better mpg?
    SE Level Member crumbut's Avatar
    Nov 2009
    Tennessee
    Anyone have tips on how to get better mpg with this engine? I read some stuff on ebay that made my BS! flag shoot up. Mod chips that promise all kinds of crap. Im thinking No way.
    let me know what you know.
  2. #2 Re: 06 GT 3.8 sc series III better mpg?
    Charles City, IA
    Dont drive like an idiot. Slap a filter on your maf sensor. New plugs & wires and a good tune.
    SMGPFC Two Nipple General
  3. #3 Re: 06 GT 3.8 sc series III better mpg?
    MO
    here's a little inside tip you won't find anywhere, and i know it helps me since i'm a bit of a lead foot. instead of pushing on the pedal where you normally do, push more towards the top so it springs a bit before it engages, that way even though you're pressing down it's not as much as you would normally.
    <brandonl2000> LMAO D!!
  4. #4 Re: 06 GT 3.8 sc series III better mpg?
    GTX Level Member cerick08GP's Avatar
    You are correct; none of the “chips” are any good at all. And since you have an 06, even a PCM tune would be a pain since you would have to swap in a 05 PCM. Which I personally don’t recommend doing. What you can do is replace your spark plugs, I recommend AL606s. Replacing the plugs is probably the only thing that will make a noticeable difference. Cleaning your MAF sensor might help also. And those are the two big “engine” things. The other big thing is keep your tire air pressures at least 30 psi.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  5. #5 Re: 06 GT 3.8 sc series III better mpg?
    Donating Users
    central ohio
    dont forget to check your air filter. what kind of mileage are you getting?
  6. #6 Re: 06 GT 3.8 sc series III better mpg?
    Nov 2009
    Tennessee
    all stock currently. Im getting around 21mpg hwy at the moment.
  7. #7 Re: 06 GT 3.8 sc series III better mpg?
    GT Level Member Perry125's Avatar
    maryland
    Wow that's pretty bad, i get 32 at 65 and 29 at 75 in my 2001 gtp according to the dic which is close.
    Do not use cruise control, speed up down hills and use very light throttle up hills.
  1. Series II vs. Series III
    By butt86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2009, 11:31 AM
  2. Difference between series 1 and series 2
    By Superchargedbuick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2009, 01:50 PM
  3. Series III downgrade to Series II
    By Rolling Thunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 02:12 PM
  4. Using Series III A/C Compressor on a Series II
    By Rolling Thunder in forum General Tech Discussion
    Last Post: 05-21-2009, 01:14 AM
  5. Series 1 2 or 3?
    By ratnick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2009, 08:08 PM
