Thread: A few upgrade questions
Results 1 to 7 of 7
  1. #1 A few upgrade questions
    Donating Users dirtmaster88's Avatar
    Sheboygan, WI
    First off I want to say that yes, I've read the "Safely Modding Your 3800 Powered Car!!" sticky.
    I have a 2004 GTP CompG (daily driver) that my goal is to drop the pulley size and then stop modding. So far I've done the following: K&N Cold air intake, 180 tstat, ssac headers, zzp flex pipe, high-flow cat, autolite 104s, autolite wires.
    After recently putting in the 104s, my gas milage dropped significantly. I'm averaging about 16-17 mpg right now. I was 20+ before. The exhaust smells very rich. I am planning a 2000+ mile trip in December and would like to get this taken care of. With the mods that I've done, what pulley size would be recommended? Also, would getting a mail order PCM that's been tuned for a smaller pulley hurt anything if I kept the pulley stock for now? I'm thinking that the PCM will help out with my gas mileage issue.
    Also does anybody know any solution for the P0420 catalyst converter code? I'm assuming it's from the high-flow cat. We do have emissions here, I was hoping this code wouldn't pop up
    Thanks Guys
  2. #2 Re: A few upgrade questions
    MO
    hmm i've heard the 104's shouldn't be used unless you go with a smaller pulley anyway or else they will hurt gas mileage
    <brandonl2000> LMAO D!!
  3. #3 Re: A few upgrade questions
    Tune + Pulley = WIN
    Tune + Stock Pulley = Alright
    Pulley with no tune = FAIL
    Reason you are getting craptastic gas mileage is because 104's are for a smaller pulley setup. I mentioned that in there too.
  4. #4 Re: A few upgrade questions
    MO
    cool so my thoughts were right. BTW, dirt, how'd those SSAC's fit once you got them in place?
  5. #5 Re: A few upgrade questions
    Sheboygan, WI
    They fit pretty nicely especially since they were used. Had a leak in the crossover but was able to take care of that with a higher quality band clamp and some elbow grease
    Any suggestions for pulley sizes with my mods and also thoughts on the code the cat is causing?
  6. #6 Re: A few upgrade questions
    MO
    a 3.6 pulley but only if you get it tuned for it
  7. #7 Re: A few upgrade questions
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    You need to have someone with a tuner to get rid of that 0420 code. I had the same code when I had a high flow cat.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  1. need upgrade help
    By 03renegade800 in forum Off Topic Discussion
    Last Post: 01-28-2010, 11:33 AM
  2. First upgrade for GTP ?
    By MikeZirpola in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 08:20 PM
  3. 98 GTP Coupe-upgrade questions-exhaust
    By Liquifire in forum General Tech Discussion
    Last Post: 07-13-2009, 12:06 PM
  4. L26 upgrade
    By tod1d in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-27-2009, 12:33 PM
  5. First upgrade...
    By DesQ27 in forum Off Topic Discussion
    Last Post: 05-13-2008, 11:13 AM
