Thread: Strange grind, timing chain?
Results 1 to 20 of 20
  1. #1 Strange grind, timing chain?
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Trying to figure out this grind I have had ever since yesterday when I overtook some slow car on the highway. It's only during high RMPs as with normal cruising everything is fine. Idle is fine, motor seems to accellerate like normal.
    Ignore the SES light in the video, it's due to a bad MAF
    I'll be checking my flexplate in the morning to see if it's cracked
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  2. #2 Re: Strange grind, timing chain?
    Norristown, PA
    surpentine belt? sounds like what happened to me.
  3. #3 Re: Strange grind, timing chain?
    Nov 2008
    Nope, belts are perfect. Only about 5k miles on both
  4. #4 Re: Strange grind, timing chain?
    Norristown, PA
    hmm..mine sounded like that. i had to replace waterpump and surpentine belt
  5. #5 Re: Strange grind, timing chain?
    Nov 2008
    Worth a shot. I can only hope it's something simple like a water pump. Have a spare in my garage haha
  6. #6 Re: Strange grind, timing chain?
    Norristown, PA
    well good luck..hopefully its not the timing chain
  7. #7 Re: Strange grind, timing chain?
    Nov 2008
    Alright, just ruled out both the pump and the flexplate. Any other ideas? Might have it checked out tomorrow
  8. #8 Re: Strange grind, timing chain?
    Apr 2009
    stockton ca
    well if it is the chain i have one for sale;-)
  9. #9 Re: Strange grind, timing chain?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Is there a constant noise at xxx rpm or is it brief?
    Also try and listen to it under the car when it happens?
  10. #10 Re: Strange grind, timing chain?
    Have you removed the supercharger belt and started it to see if it is actually engine related and not the blower?
  11. #11 Re: Strange grind, timing chain?
    Nov 2008
    I'll give the blower a shot in the AM. As far as it being constant, no it's not. It's only around thr 4K range. I haven't seen if it stays all the way to the shift just due to trying not to cause any serious damage, if it so happens to be a big problem
  12. #12 Re: Strange grind, timing chain?
    in a house
    Harmonic dampener maybe?
  13. #13 Re: Strange grind, timing chain?
    Nov 2008
    That's what i'm thinking it might be. Just confused on why it's not a constant thing?
    Anyhow, went ahead and got another vid of it with the supercharger belt off
  14. #14 Re: Strange grind, timing chain?
    in a house
    Quote Originally Posted by ninnyGTP View Post
    If the rubber in the dampener goes to crap sometimes it can only be heard at the higher rpm's. I would pull the belts off and run it and see if the noise is still there. Maybe even a bad tensioner pulley. Just guesses?
  15. #15 Re: Strange grind, timing chain?
    Nov 2008
    I'll try anything at this point haha
  16. #16 Re: Strange grind, timing chain?
    Nov 2008
    Nevermind, new plan. Just going to pull the motor and stick in an L32
  17. #17 Re: Strange grind, timing chain?
    Thats an expensive alternative...
  18. #18 Re: Strange grind, timing chain?
    Nov 2008
    haha not even. After selling my L67 i'll only be biting about $200 plus another $100 or so for the L32-L67 TB adapter
    In my mind, that's an AWESOME alternative.
  19. #19 Re: Strange grind, timing chain?
    Also a plus if its been well taken care of and/or low mileage.
  20. #20 Re: Strange grind, timing chain?
    SE Level Member Boostd1's Avatar
    Thornton, Colorado
    L32 ftw
    "The only sustainable competitive advantage is the ability to learn faster than the competition."
  1. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  2. What's up with the timing chain issues
    By joesforspeed in forum Turbo
    Last Post: 07-02-2009, 09:47 PM
  3. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  4. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
