Thread: Timeing a double roller setup???????
Results 1 to 7 of 7
  1. #1 Re: Timeing a double roller setup???????
  2. #2 Re: Timeing a double roller setup???????
    Wichita, KS
    For the GT's and GTP's just line the dots up, they will both work, and run just fine. Be sure to hand turn the motor over a few times before re installing your valve train to make sure its in perfect time.
    If you want to get really into it, use a degree wheel, but you will find that they are still ok lining the dots up.
    Like said above, the GTP's run even better with a little mechanical cam retardation on the top end.
    ~F~
  1. Those of you with double roller timing chains....
    By Reptile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 11:49 PM
  2. my old setup
    By whitcomb in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2009, 06:49 PM
  3. AN Fuel Line Setup
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2008, 06:26 AM
  4. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
