Hello everyone. I just bought a '99 GTP, all stock, and I am getting P0171 lean bank 1 consistently...
Got set up with a scan tool on my laptop and sure enough, the LTFT's sit at 16.4 at idle and slow cruise, they seem to lower when the engine is under more load.
Except for 10 in/Hg at idle, all other sensors look good and I have started to examine the engine for vacuum leaks.
I noticed that if I remove the oil filler cap while the engine is running I get a stumble out of the motor, and when I spray carb cleaner in the front valve cover, the motor does change rpm temporarily.
Is this typical, or am I in the right area? Should I check the PCV system? The PCV valve itself is new.
Thanks for any advice,
Jason
