Thread: Busted piston!!!!
Results 1 to 16 of 16
  1. #1 Busted piston!!!!
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    Well I finally got to tear down my engine for a rebuild. Pulled the heads and.....sure enough I have a busted piston. It doesn't appear to have damaged the head or valves. But will have to take a closer look at the valve seats. Just an update for anyone keeping up on my slow project. Again any input would be appreciated. Also, I am looking at getting a larger Cam. Any suggestions??? 3.8 S/C w/ 5 spd.
    Lambokit to be built!!!!!
  2. #2 Re: Busted piston!!!!
    GT Level Member tylerbinski's Avatar
    Canada
    Are you doing a lambo kit on a fiero?
    I was looking at those kits lastnight actually... did you stretch the frame?
    Sorry to hear about the busted piston.
    I have the XP cam, i like it, its pretty decent, just gotta get the machined valve spring retainers or they will contact the valve seal and chew them up, then you burn oil!
    got any pics on your project
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  3. #3 Re: Busted piston!!!!
    if youre getting the heads ported go for one of the bigger cams (XPZ, IS3, TEP, or go custom). did you buy this motor from someone or is it your fault?
  4. #4 Re: Busted piston!!!!
    TEP FTW.
    3800 Performance just made one that I cancelled an order on so they have one lying around
  5. #5 Re: Busted piston!!!!
    PA
    Quote Originally Posted by lambokit View Post
    Should just be able to replace the piston with a good one and keep on truckin. Just check your heads like you mentioned. And make sure the walls aren't scored that bad. Shouldn't be too much of an issue though.
    2001 GSE
  6. #6 Re: Busted piston!!!!
    Apr 2009
    Radford, Virginia
    Yes it is based on a Fiero. No it's not stretched. And I do have pics. Just go to my profike and look at the Lambo Kit album.
    Bio, I got the engine like that. And I am going to go with a bigger cam. But there is no one around here (that I'm aware of) to get a good tune.
    I will be doing a port/polish on the heads and intake. Want to get some headers, but those are high $$$$. I am also going to machine me an intercooler once I find the right cooler core to mount in it. That should take care of any KR. At least that's what i've read.
    Will probably have the block bored .010 over and get new pistons. I want this thing right. Cause I'll be running the piss out of it everychance I get.
  7. #7 Re: Busted piston!!!!
    anyone that knows how to work on the old buick 231 heads (grand national or t-type) should be fairly fluent with our heads. go big or go home. the fiero should be a super fun car to play with.
  8. #8 Re: Busted piston!!!!
    Apr 2009
    Radford, Virginia
    Anyone know where a good place to buy some forged pistons for a 3.8 S/C.Might as well order some good pistons to go with the X-P HOT cam kit I'm looking at...
  9. #9 Re: Busted piston!!!!
    forged pistons arent worth it. you can buy two new blocks for the price of those. if youre not knocking like crazy you wont punch holes in pistons.
  10. #10 Re: Busted piston!!!!
    Apr 2009
    Radford, Virginia
    Sweet. Thanks Bio. I have a spare S/C engine. I may just pull a Rod & Piston from the other one, Replace all rings, bearings and gaskets and put her back together. What do you think of the XP Hot cam???
  11. #11 Re: Busted piston!!!!
    May 2008
    staten island,NY
    get an L32 it has coated pistons and powdered rods
  12. #12 Re: Busted piston!!!!
    Apr 2009
    Radford, Virginia
    I've tried to search but quickly find out. What's the difference between an L67 & L32? Not to sound like an idiot. I just don't know.
  13. #13 Re: Busted piston!!!!
    What quikGT said...that's about it...and the GenV blower and returnless fuel system.
  14. #14 Re: Busted piston!!!!
    Feb 2013
    greenfield in
    i just had a piston break last week on my gtp. it is just my daily driver with 153,000 miles on it. i never heard any knock before it broke. i always used good gas (93 octane). i just sped up on the highway and it it made a noise. i could not believe it broke. i just need to get it back on the road . can i have another supercharged 3800 installed.
  15. #15 Re: Busted piston!!!!
    Last post was Nov 19, 2009. Check the dates before you bump a ancient thread dude.
    04 Comp G.
  16. #16 Re: Busted piston!!!!
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Rookie.
  1. Busted St-11's need Replacing So..
    By SDGTP99 in forum Tires & Wheels
    Last Post: 10-16-2009, 02:12 PM
  2. '04 rear caliper piston
    By 04GT2 in forum Brakes/Suspension/Chassis
    Last Post: 07-22-2009, 12:26 PM
  3. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  4. Piston + Valve = No Bueno
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2009, 12:12 PM
  5. Window Busted Out
    By GreenPrix in forum Off Topic Discussion
    Last Post: 12-08-2008, 09:05 AM
