Thread: Busted St-11's need Replacing So..
Results 1 to 8 of 8
  1. #1 Busted St-11's need Replacing So..
    Wichita
    One of my rims got chewed up when my front LH wheel came off the other day. Im thinking of replacing them all with maybe these or something else:
    GA 18 BK ST-15 WHEELS RIMS 5 LUG MAZDA 3 6 WRX RSX TSX:eBay Motors (item 130336239741 end time Oct-16-09 12:54:19 PDT)
  2. #2 Re: Busted St-11's need Replacing So..
    those would look good on a black car 18 or 19inch
  3. #3 Re: Busted St-11's need Replacing So..
    Jan 2009
    Tallahassee, FL
    I like them, your wheel came off??
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  4. #4 Re: Busted St-11's need Replacing So..
    Wichita
    Yeah first time thats happened. But its not the first time ive had studs break off. My car is 10 years ol. Thing are gonna break lol. I might get those rims.
  5. #5 Re: Busted St-11's need Replacing So..
    GT Level Member Perry125's Avatar
    maryland
    45mm offset is a bit much?
  6. #6 Re: Busted St-11's need Replacing So..
    Quote Originally Posted by Perry125 View Post
    a bit much as in too high or too low? stock is +52mm, so its fine so far as the fit, but if you want that mean look with the wheels sitting flush with the fenders you need something close to +30mm. although, the lower you go, the more likely you are to rub.
  7. #7 Re: Busted St-11's need Replacing So..
    maryland
    Yeah i meant that the wheels sitting a little more flush with the fender would look better.
  8. #8 Re: Busted St-11's need Replacing So..
    Wichita
    I'd get these if I knew the name & where to find them:
    http://image.automobilemag.com/f/808...mic_brakes.jpg
    Yes I HAVE seen them on a GP before.
  1. Replacing...
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-13-2009, 10:17 PM
  2. Busted Front Swaybar
    By Pontiac Warrior in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:33 AM
  3. replacing alternator
    By jbizach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-02-2009, 11:05 PM
  4. Replacing a gear box??
    By kacarter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 07:30 PM
  5. Window Busted Out
    By GreenPrix in forum Off Topic Discussion
    Last Post: 12-08-2008, 09:05 AM
