Thread: Vehicle wont go in gears?
Results 1 to 3 of 3
  1. #1 Re: Vehicle wont go in gears?
    SE Level Member Spazztic2003's Avatar
    Oxford, MI
    I'd just get a whole new tranny if I were you. That sounds like a whole mess of problems.
    A fan of Pontiac and their cars since my birth in Pontiac.
    Proud owner of the world's worst '98 GTP, falling apart in every way!
  2. #2 Re: Vehicle wont go in gears?
    A transmission works on the movement of fluid. Based on your description it sounds like there's an issue with the filter being plugged etc by something and no fluid moving.
    I saw this type of behaviour once when a lot of material would block the filter. On start up, all that material is at the bottom of the pan and the filter can pull some fluid, as the fluid is pulled the material clogs the filter and the trans stops functioning.
  1. Vehicle Speed Sensor????
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2022, 01:38 PM
  2. Vehicle Speed Sensor
    By bct717 in forum Chevrolet Monte Carlo
    Last Post: 12-08-2010, 08:39 PM
  3. So What Really Grinds Your Gears.
    By GTBabyGirl in forum The Rant Forum
    Last Post: 08-27-2009, 11:26 AM
  4. whoopin on a unknown vehicle
    By johnnyj773 in forum Track Sessions and Kills
    Last Post: 07-02-2008, 12:22 PM
  5. Other vehicle section.
    By gmboy in forum Forum Bugs/Suggestions
    Last Post: 12-20-2007, 10:30 PM
