Thread: Vehicle wont go in gears?
Results 1 to 3 of 3
  1. #1 Vehicle wont go in gears?
    canada
    my vehicle is 97 grandprix gtp supercharged 3800 seriesII. My car starts normally, everything is fine with it, except when ever i switch it to R,N,D,3,2,1 it works only for like 1 minute and then everything acts like the car is in Neutral. What i am trying to say is that, when i freshly start my car and put the shifter from P to D, it goes in gear but then when its warmed up it wont simply goes in any gears at all, then i switch it to NEUTRAL or Reverse nothing happens, no switching movement nothing, then i turn my ignition off, and then restarted my vehicle same thing, it shifts to all of them R,N,D,3,2,1 but as soon as i start to drive it doesn't want to pull the vehicle. I checked the shifter cable, its fine and i also inspeted the tranny it was replaced by the previous owner back in 2008 june. u think it my torque converter? i hope my explaination is understandable!
    PLZZ ANY HELP WOULD BE APPRECIATED
  2. #2 Re: Vehicle wont go in gears?
    SE Level Member Spazztic2003's Avatar
    Oxford, MI
    I'd just get a whole new tranny if I were you. That sounds like a whole mess of problems.
    A fan of Pontiac and their cars since my birth in Pontiac.
    Proud owner of the world's worst '98 GTP, falling apart in every way!
  3. #3 Re: Vehicle wont go in gears?
    A transmission works on the movement of fluid. Based on your description it sounds like there's an issue with the filter being plugged etc by something and no fluid moving.
    I saw this type of behaviour once when a lot of material would block the filter. On start up, all that material is at the bottom of the pan and the filter can pull some fluid, as the fluid is pulled the material clogs the filter and the trans stops functioning.
  1. Vehicle Speed Sensor????
    By Luminary in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2022, 01:38 PM
  2. Vehicle Speed Sensor
    By bct717 in forum Chevrolet Monte Carlo
    Last Post: 12-08-2010, 08:39 PM
  3. So What Really Grinds Your Gears.
    By GTBabyGirl in forum The Rant Forum
    Last Post: 08-27-2009, 11:26 AM
  4. whoopin on a unknown vehicle
    By johnnyj773 in forum Track Sessions and Kills
    Last Post: 07-02-2008, 12:22 PM
  5. Other vehicle section.
    By gmboy in forum Forum Bugs/Suggestions
    Last Post: 12-20-2007, 10:30 PM
