Thread: Pulling my engine
Results 1 to 13 of 13
  1. #1 Pulling my engine
    Apr 2009
    stockton ca
    On saturday is there anything tricky about the pull to watch out for
    I left the trans B!tch bolt out when i put the trans in so it wont be an issue
    So its just disconect all electrical,drain oil and coolant,dogbones,engine mount , dp from rear manifold, and fuel rails
    im sure theres a couple tricks or ways of easing the proccess
    Then it will be cleaned up disassembled and the lower end goes to a awesome engine build and i get to start my build
  2. #2 Re: Pulling my engine
    May 2008
    McHenry IL
    you left a trans bolt out?
  3. #3 Re: Pulling my engine
    SE Level Member drewz313's Avatar
    Morgantown, wv
    I think he talking about that one bolt by the Transmission that you can get out but you can't get back in. It on the motor mount toward the firewall.
  4. #4 Re: Pulling my engine
    Donating Users kfish's Avatar
    Ohio
    or is he talking about the bellhousing bolt that comes in from the engine into the tranny that you have to use about 6 extensions for?
  5. #5 Re: Pulling my engine
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by wickedintent79 View Post
    Put a jack under the passenger side part of the tranny and just tilt it up a bit to get the engine to come out and in easier also take the nuts off of the top of the engine mount. Take bolts out holding the tranny to engine near diff. Take torque converter bolts off, starter off. Take off power steering pump, take the A/C compressor off and move both out of the way. Disconnect heater hoses, radiator hoses, tb cable, all electrical connections, take oil filter off to give a little extra room to clear engine bay. Do something with the rear manifold, either disconnect at head and crossover and let it hang there or take the dp bolts out and go that way.
  6. #6 Re: Pulling my engine
    its the bellhousing bolt that comes in from the wrong way. a lot of people take it out.
  7. #7 Re: Pulling my engine
    Apr 2009
    stockton ca
    Yea the bolt on the backside of the bellhousing, I have the extension for it at school but not at my house. And i know the bracket near the oil pres sensor is a bastard but i got it out before..
    Every one else in clas is bringing in little 4bangers or presmog sb chevys Im the only one bringing in a newer comp controlled engine
    The last class only had 1 group finish and drive out 2 groups seized there engines after 45 sec run time
  8. #8 Re: Pulling my engine
    Apr 2009
    stockton ca
    The engines out Wasnt bad at all took like 3 hours and not at a rushed pace
    Only bad thing that happened was the parts tray i was useing flipped and mixxed all my nuts and bolts up so Im not happy about that
    Hopefully we will have its broke down to almost nothing tomorow and the block will be sent out to the machine shop by friday
  9. #9 Re: Pulling my engine
    If you have questions as to which bolts go where, post them up in groups with numbers and most of us can tell you what they are.
  10. #10 Re: Pulling my engine
    Apr 2009
    stockton ca
    Very cool may have to do that due to the fact it was me and a my buddy pulling them so I didnt actually see them al come out
    I have a few print outs off of si2000 aswell so im not to worried
  11. #11 Re: Pulling my engine
    And most bolts really only fit in one place.
  12. #12 Re: Pulling my engine
    HUDSON
    How much more difficlut iis it too pull the engine with the tranny still attached?
    I'm going to need to do this in the future, gotta rebuild the tranny.
    Dean
  13. #13 Re: Pulling my engine
    Quote Originally Posted by QUICKSILVER462 View Post
    Dean
    you gotta pull the axles and tranny fluid lines, but thats about it. if you dont need to then leave the transmission there.
  1. Pulling to the Ditch and Vibrating
    By Hawkins97 in forum General Tech Discussion
    Last Post: 08-05-2009, 02:16 AM
  2. Pulling the motor write up
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2009, 02:59 PM
  3. Pulling out head unit
    By keenan00gtp in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2009, 11:25 AM
  4. Pulling a Pulley
    By jagamite in forum General Tech Discussion
    Last Post: 11-14-2008, 08:12 AM
  5. FWI without pulling the bumper.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 05-14-2008, 08:35 AM
