Thread: timing slipped. Interferance? can chain be repaced in car?
Results 1 to 6 of 6
  1. #1 timing slipped. Interferance? can chain be repaced in car?
    Feb 2009
    NE
    Piced up a 1997 GTP for $200. Guy said they told him the timing chain slipped. It spins over like the plugs are out and backfires a bit. Do these engines have a chance of valves hitting the piston in this situation? I assume the chain can be replaced with enigine in car? Should I remove the SC snout to make it easier to get to and replace the coupler while at it?
  2. #2 Re: timing slipped. Interferance? can chain be repaced in car?
    yes, its an interference motor. the valves will hit the pistons if the chain breaks unless youre lucky as all hell.
    the chain can be replaced with the engine in the car from the passenger fenderwell. you might have to drop the subframe a little bit to get the crank pulley off.
    the coupler is most easily replaced by taking the blower off and disassembling that way.
  3. #3 Re: timing slipped. Interferance? can chain be repaced in car?
    Feb 2009
    NE
    any simple way to know if the valves are bent?
  4. #4 Re: timing slipped. Interferance? can chain be repaced in car?
    i would just take the heads off. its the easiest way to figure out what you have to deal with.
  5. #5 Re: timing slipped. Interferance? can chain be repaced in car?
    Charles City, IA
    you can try a cylinder leak down and compression test.
    SMGPFC Two Nipple General
  6. #6 Re: timing slipped. Interferance? can chain be repaced in car?
    that would work, but if the chain is broke its damn near a certainty that something is broke on the inside.
  1. timing chain
    By pure in forum General Tech Discussion
    Last Post: 08-16-2009, 02:00 PM
  2. What's up with the timing chain issues
    By joesforspeed in forum Turbo
    Last Post: 07-02-2009, 09:47 PM
  3. Which timing chain to get.
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 09:01 AM
  4. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
