Thread: starting to lose my mind
Results 1 to 20 of 22
  1. #1 Re: starting to lose my mind
    Wausau, WI
    I think the pcms are as follows:
    97-only
    98-02 same
    03 only
    That is the way the vendors break them down when you order them. I know the 03 has different tranny settings than the rest. Not sure on what the difference is exactly between the 97 and the newer versions, but they are not a direct swap as far as the settings go.
  2. #2 Re: starting to lose my mind
    sudbury, ontario
    lol of course mine is the only specific year...**** sakes...
  3. #3 Re: starting to lose my mind
    sudbury, ontario
    so it turns out it was my ignition switch i figured that was the only reason my fuses werent getting powered up so i started "hotwiring" the car using the key to crank and a jumper wire to ign power and it started right up it wasnt until i powered it up that i realized none of my dash lights had been on or my DRL lol so now it has a fancy toggle switch
  1. what comes to mind when driving?
    By Bio248 in forum Off Topic Discussion
    Last Post: 08-25-2009, 06:27 PM
  2. Mind degerously wondering
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 10-08-2008, 10:38 PM
  3. BOSE with a mind of its own....
    By armcclure in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2008, 02:52 PM
