Thread: starting to lose my mind
Results 1 to 20 of 22
  1. #1 Re: starting to lose my mind
    Sorry..I don't have the tach info here. It would seem that you have no spark though. You've actually tested to ensure taht the injectors are pulsing and you have fuel into the cylinders right? And also checked for spark?
  2. #2 Re: starting to lose my mind
    sudbury, ontario
    ya sry i have no spark..tons of fuel at schrader, i put a peanut bulb in an injector wire and got nothing when cranking. I have no idea why or if its even related but when i turn my key on my fuel pump relays go insane, my plastic line goes nuts, clicking on and of..ive tried many pairs of relays in both f/pump and the spd cntrl..i just got a ICM from a buddy to try, i took the plug off there it LOOKS fine, so does the cam and crank sensor plugs..there is 2 red wires in the ICM connector that test as grounds?
  1. what comes to mind when driving?
    By Bio248 in forum Off Topic Discussion
    Last Post: 08-25-2009, 06:27 PM
  2. Mind degerously wondering
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 10-08-2008, 10:38 PM
  3. BOSE with a mind of its own....
    By armcclure in forum Audio, Security & Visual Electronics
    Last Post: 09-17-2008, 02:52 PM
