Thread: Can I remove the throttle body screen??
Results 1 to 20 of 26
  1. #1 Re: Can I remove the throttle body screen??
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by TDCRacing View Post
    i am about to port it and was just wondering if i could leave it off for maybe a little better ailflow.i know it is suppose to even out airflow but just wanted to make sure it wont have any side affects.tia
    The quick answer is leave it on. The MAF needs that screen so it's calculations won't be skewed.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Can I remove the throttle body screen??
    PA
    Yes, you can remove the TB screen. Should you? Nope. People starting doing that a couple years ago because they thought it would improve the air flow. While it does do that, it will allow the incoming air to create turbulence and cause erratic MAF sensor readings. So while your car may run a little better because of a very small amount of air extra, it will run worse because it won't be able to meter the air accurately.
    2001 GSE
  1. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  2. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
  3. Throttle Body swap
    By Berger in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2008, 08:35 PM
  4. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
  5. Ported and Painted Throttle Body
    By GTP SE in forum Visual/Body Modifications
    Last Post: 01-04-2008, 01:38 PM
