Thread: Can I remove the throttle body screen??
Results 1 to 20 of 26
  1. #1 Re: Can I remove the throttle body screen??
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    way to open another can of worms, haha. I have been guilty of it a couple of times though.
    This debate could rage on and on, as it is a huge debate among gm ls based/lq truck owners (aka silverado 4.8/5.3/6.0) to gain a minute performance for no money whatsoever. Jist of it is that there is proof that it gains performance and there is proof that it loses performance, so most people just leave it on for the fact that it doesn't hurt anything as far as hp (maybe 1-2 at most).
    I would leave it on for the simple fact that most people agree that it doesn't hurt anything.
    In case you want even more info it is discussed almost daily on ls1tech.com in the 5.3 truck section and fullsizechevy.com also pretty regular and I know they have dyno sheets to support both ends of the "argument".
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  2. #2 Re: Can I remove the throttle body screen??
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    GM didn't put that screen there to stop rodents from crawling in to your engine or to restrict airflow to limit your HP.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Can I remove the throttle body screen??
    TDCRacing
    Guest
    true....
  4. #4 Re: Can I remove the throttle body screen??
    St Louis MO
    There is a book called Engine Management Advanced Tuning by Greg Banish. Greg is a GM OEM Calibration Engineer. His book is a great read. Referencing this subject, checkout pages 25 though 28 on the MAF sensor. He talks about the removal of the laminar screens.
    2010 Camaro SS LS3
  5. #5 Re: Can I remove the throttle body screen??
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by IndeedSS View Post
    Oh man. Don't post info about tempting technical books. My wallet doesn't like that.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  6. #6 Re: Can I remove the throttle body screen??
    St Louis MO
    Quote Originally Posted by Going Too Phast View Post
    It is a very good book. IIRC, it wasn't very expensive through Amazon. Print is large and there is a lot of pictures. The text will be basic for more experienced people, as for me I still find myself going back to look things over.
    I would love to go take one of his 2 day tuning seminars.
    The book:
    Amazon.com: Greg Banish: Books
    2010 Camaro SS LS3
  7. #7 Re: Can I remove the throttle body screen??
    GTP Level Member David99GTP's Avatar
    Florida
    The book:
    Thanks, I'd like to get a little more informed on the subject. I'll look it up on amazon
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  8. #8 Re: Can I remove the throttle body screen??
    Oklahoma
    The book:
    I just ordered a copy of the book, but for what it is worth, I have my screen in. I took it out for a while maybe a year after getting the car. I cant recall any noticeable performance differences but it always seemed that the idle was a bit rougher and responsiveness may have been off.
    May be my imagination but it prompted me to put it back in a couple weeks later.
  9. #9 Re: Can I remove the throttle body screen??
    PA
    So for those of us that are not going to by the book, what does it say about it?
    2001 GSE
  10. #10 Re: Can I remove the throttle body screen??
    St Louis MO
    Quote Originally Posted by Zef_66 View Post
    Basically, that the airflow is turbulent and does not flow the same across the MAF. The screen smooths or averages out the flow across the MAF. The most gain seen was 4HP and that was on a V8. If the airflow across the MAF is not accurate your tune will not be correct. My poor excuse for a reader digest version of 3 pages of good information on the operation of the MAF.
    I remember seeing you in a lot of threads about tuning pertaining to the PT. I figured you more than anyone else would find this book interesting.
    2010 Camaro SS LS3
  11. #11 Re: Can I remove the throttle body screen??
    PA
    I am sure I would find it interesting, but I don't have the time to sit down and read anymore. Unless I could somehow find it on tape, then I could listen to it in the car while I am driving to and from work!
    But yeah, I am sure it would be a great read, and great info, I just don't have the time to sit down and do it. Too many other projects to work on.
    2001 GSE
  1. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  2. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
  3. Throttle Body swap
    By Berger in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2008, 08:35 PM
  4. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
  5. Ported and Painted Throttle Body
    By GTP SE in forum Visual/Body Modifications
    Last Post: 01-04-2008, 01:38 PM
