Thread: O2 Sensor with headers
Results 1 to 18 of 18
  1. #1 O2 Sensor with headers
    GT Level Member Xorbex's Avatar
    Canada
    Got a 05 GTP going to put headers with dp and no cat. What happens to the rear O2 sensor?
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: O2 Sensor with headers
    you take it out, throw it in the trash, and disable the o2 code in your PCM otherwise you get to stare at an SES light forever.
  3. #3 Re: O2 Sensor with headers
    Banned - Busted For Scamming
    Feb 2009
    Or just take the bulb out.
  4. #4 Re: O2 Sensor with headers
    that doesnt let you pass emissions or know when something actually IS wrong with your car.
  5. #5 Re: O2 Sensor with headers
    Feb 2009
    I live in florida, no emission
    If my car is running bad, i plug the scanner in.
  6. #6 Re: O2 Sensor with headers
    Canada
    What will happen if i just leave it in? Will that hurt the car or its performance. THe only problem is that I am no where near a place to get a tune and have no knowledfge on it myself.
  7. #7 Re: O2 Sensor with headers
    nothing will be hurt, but its basically useless if you dont have a cat.
  8. #8 Re: O2 Sensor with headers
    Canada
    Im just thinking about saving $200 and going catless but if its better to run a cat ill get a high flow. Will the high flow still give me O2 errors?
  9. #9 Re: O2 Sensor with headers
  10. #10 Re: O2 Sensor with headers
    Charles City, IA
    Cat will make it sound better too.
    SMGPFC Two Nipple General
  11. #11 Re: O2 Sensor with headers
    Donating Users blowfishRus6's Avatar
    g.a.
    with the pacesetters the rear o2 is moved further down the exhaust, with the suplied extension i retained the 02. it threw a code at first for no cat, but went away shortly after.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: O2 Sensor with headers
    Or...just delete the code and do it the right way the first time via a tuner...find someone close to you thats able to do that.
  13. #13 Re: O2 Sensor with headers
    Canada
    id love to go somewhere near me for a tune but thats not an option. Too far away. No-one within 400 miles at least
  14. #14 Re: O2 Sensor with headers
    g.a.
    like said, mine threw a code for all of 5 mins then it went away. its really not an issuie
    its slow.
  15. #15 Re: O2 Sensor with headers
    or just buy a cheapo scanner and delete it when it pops up LOL
  16. #16 Re: O2 Sensor with headers
    g.a.
    but it went away... on its own.
    car just had to cycle threw. no need for the scaner.
    its slow.
  17. #17 Re: O2 Sensor with headers
    Wausau, WI
    shouldn't it be tuned, cat or not, with headers to prevent it from running leaner? Or is this not an issue?
  18. #18 Re: O2 Sensor with headers
    Charles City, IA
    Yes they will make if leaner.
  1. o2 sensor
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 06:12 PM
  2. maf sensor
    By betsgtp in forum General Tech Discussion
    Last Post: 04-21-2009, 02:15 AM
  3. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
  4. O2 Sensor OR MAP
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 05:35 PM
