Thread: custom fwi build
Results 1 to 20 of 29
  1. #1 custom fwi build
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    i just made a 3" fwi out of a cold air intake 4 a 96 honda accord 4 my 98 gtp, came out looking real good. i have a pic, hopefully i did it rite and uploads.
  2. #2 Re: custom fwi build
    GEORGIA
    it keeps saying upload fail when i try 2 load the pic.
  3. #3 Re: custom fwi build
    GEORGIA
    well it atleast downloaded to profile, so if any1 want 2 check it out u can there.
  4. #4 Re: custom fwi build
    michigan
    there ya go man
  5. #5 Re: custom fwi build
    GEORGIA
    wow thanx, how did u do that so i know 4 next time. ive never uploaded a pic b4 on here.
  6. #6 Re: custom fwi build
    michigan
    once you have it hosted to the site, right click on the pic and copy the pic's address, then paste that address on this page between these brackets [img*][/img*] (minus the *'s)
  7. #7 Re: custom fwi build
    Banned
    Wichita Falls, Texas
    Use [IMG] [/IMG] tags
  8. #8 Re: custom fwi build
    GEORGIA
    cool. thanx
  9. #9 Re: custom fwi build
    Good deal on getting her in the fender...now make it 4"
  10. #10 Re: custom fwi build
    GEORGIA
    i would have but i didnt have 4" pipe or filter and i got all this 4 free. im atleast gonna heat wrap it to tho.
  11. #11 Re: custom fwi build
    Don't waste your time heat wrapping it...put heat wrap on your manifolds if anything...that will help more than wrapping your intake...and wrap the crossover too...
    Take off that engine cover also...that likes to trap in a bunch of heat.
  12. #12 Re: custom fwi build
    GEORGIA
    k, will do. NOW I GOT SOME DUSTING TO DO UNDER THAT COVER.
  13. #13 Re: custom fwi build
  14. #14 Re: custom fwi build
    Wausau, WI
    both of those intakes are too small.
    I second that motion, big time...
  15. #15 Re: custom fwi build
    Quote Originally Posted by Liquifire View Post
    I say...get more mods...big time.
    The guys tried at least give him some credit...at least he didn't bolt the filter to the throttle body with no other mods.
  16. #16 Re: custom fwi build
    Jan 2009
    Tallahassee, FL
    Isn't the opening of the TB more than 3"? I'd go at least 3.5", that's what I got right now, need to build a bigger one now though. You did do a good job, looks great.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  17. #17 Re: custom fwi build
    GEORGIA
    car has a 3.4 pulley, 3" catless downpipe (ubend deleted), 180 stat, al 104's, 8mm wires, 3" exhaust split to 2.5" turbo mufflers and now the 3" fwi. intense pcm coming this week and plog hopefully sometime next month.
  18. #18 Re: custom fwi build
    Wausau, WI
    I agree...the shiny pipes look cool, but they are probably actually helping you due to the fact that you appear to be running a stock tune(until the intense arrives) with the 3.4. You will probably be starving for air if you are not already at this point. The plog will help out a lot with reducing your KR. Are you scanning somehow now? It is too bad they don't make the nice shiny tubing with a good filter and sell it as a kit in the 4"...That would be worth some cash. Good luck modding though.
  19. #19 Re: custom fwi build
    GEORGIA
    yea i know. thanks.
  20. #20 Re: custom fwi build
    Eureka, IL
    Honest question: Why is a 3" intake too small if a 3" exhaust is more than big enough? I personally run a 4" intake, but I'm just curious.
  1. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  2. Clean gtp build
    By Davisgtp in forum Off Topic Discussion
    Last Post: 09-21-2009, 06:07 PM
  3. want to build a real custom box.
    By justwhisen in forum Audio, Security & Visual Electronics
    Last Post: 06-17-2009, 10:52 AM
  4. Engine Build
    By ChrisGTT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2008, 04:18 AM
  5. First wash after the new build.
    By Biggie in forum Visual/Body Modifications
    Last Post: 05-10-2008, 09:32 AM
